Old 04-14-2003, 11:36 AM   #1
lotik
drag it like you stole it
desktop dyno my truck?
what info would you need to do it? possible hp/torque and quartermile time?
negative camber //LA\\
lotik is offline   Reply With Quote
Old 04-14-2003, 01:18 PM   #2
BigDaddyCMU
You'll need pretty much all the specs for your motor. Bore, stroke, compression ratio, cam specs, flow number for the head, etc. I've only used it a time or two, but I think you can get rough numbers with only limited info. I downloaded the software for free from Morpheus. It's a program like Napster. It's pretty cool stuff though. Not sure if it does quarter mile times or not though.
BigDaddyCMU is offline   Reply With Quote
Old 04-14-2003, 01:26 PM   #3
70c10
67-72 Addict!
70c10's Avatar
Once you get your REAR wheel HP numbers and you know the weight you can go to www.prestage.com and get a rough estimate for 1/4 mile times.
Jim
1970 C/10 Fleetside w/Ghost Flames
Lowered 4.5" front and 4" rear (Raked)
355/350 Turbo w/shift kit
10" Redneck Performance Verter w/2500 stall
Hooker Super Comps part#2808-1
Performer RPM Air-Gap
12 Bolt w/3:73 gears- Eaton Posi
Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads
70c10 is offline   Reply With Quote
Old 04-14-2003, 02:30 PM   #4
lotik
its a stock crate 350. holley street dominator intake, edelbrock 600 carb. summit block hugger headers. dual turbo mufflers.
i know it isnt that much hp..just curious.. seems really slow compared to my 93 chevy c-1500 350 i had. heh
Old 04-14-2003, 03:16 PM   #5
bigjimzlll
bigjimzlll's Avatar
this is VE2000..give me your email..and ill send you the file..I cant load it to the board
It's called "drag racing" if they called it "tic..tic..WHAM!..BANG! F*&K!!!", they'd have to keep the magazines under the counter with the other men's publications
click the clicky to join the site....
67 lwb..first hotrod in 25 years..540 best ET is 9.45 @ 141.44
Anderson,CA
bigjimzlll is offline   Reply With Quote
