10-08-2011, 11:20 PM | #1 |
C10 Club Tennessee
Confused about Motor Mount options
I'm confused about the motor mount options for the LS1's. Which is probably a sign I shouldn't delve into this, but I've never obeyed those signs in the past so why start now.
I guess I'm confused about the $25 adapter plates compared to the $219 ECE kit. What's the difference and which one is more "cost effective" The LS1 I'm picking up has the original A/C compressor still with it. I'm putting this in my burb and will have to go Vintage Air at some point. I know that's another question in it's self. I'm not trying to make this look good, just want it bolted soundly to the frame.
Bryan www.gmtruckshow.com Project "Andes"-Halen's First Truck Project: Patina Burb for he is God’s servant for your good. But if you do wrong, be afraid, for he does not bear the sword in vain. For he is the servant of God, an avenger who carries out God’s wrath on the wrongdoer. Romans 13:4 |
10-09-2011, 09:47 AM | #2 |
Re: Confused about Motor Mount options
The adapter plate allows you to bolt up a standard sbc mount to the ls block. -This works for some to use the existing mounts to mount into the chassis. I have just done this in my 71.
The other kits gives you everything to get the engine mounted to the frame using nothing from your original setup. |
10-09-2011, 11:00 AM | #3 |
C10 Club Tennessee
The only thing I have left is the original stands in my 72.
10-09-2011, 12:29 PM | #4 |
meowMEOWmeowMEOW
its hard to beat the cost of the adapter plates. There are a few different ones out there, with different offsets that can move the engine forward or back for clearance.
Even with newer mounts and hardware, the adapter plate setup cost me no more than $55. I didn't see a reason to spend another 150$ that could go elsewhere.
10-09-2011, 02:54 PM | #5 |
I did modify mine to set the engine back. I had to cut the front hole that would hold the upper from sbc mount bolt, to gain cleance for the AC with the factory brackets ( on the 5.3). I then ended up fipping the mounts side to side and dilling and tapping one hole for the new location of the sbc mount.
In the end, the frame mounts are in the two rear holes on upper frame flange, and the trans crossmember is in the most forward set of holes. This should push the engine back to make it sit a bit tighter to the firewall. |
10-09-2011, 09:05 PM | #6 |
Still Learning
I used the cheaper style plates on my install with what I think are the 73 up style engine stands. I had to drill new holes for inboard mounting holes. I also moved the passenger side back to accommodate the a/c compressor. Which means I had to cut the angled portion that side adapter plate and then made a brace to use the last hole and carry the weight on the back. The reason I went with this style stand, I think they are a better design and I never liked the 72 back design (I had one break on me and the whole engine would raise up.
Here are the pictures I have, I will try to get more when I get back to my build.
Mike "69 Short Wide" My Project 86 Silverado Landen's Project Instagram: @mcbassin My Website C/10 Club Oklahoma Facebook Group Last edited by mcbassin; 10-11-2011 at 11:24 AM. |
10-11-2011, 11:12 AM | #7 |
C10 Club Tennessee
This is what I have now
10-11-2011, 11:22 AM | #8 |
Still Learning
I had those same mounts too but I really don't care for the motor mounts on this style. (just my opinion though). My reasoning, I have a 402 in my 70. It used to eat those mounts for lunch. when they fail the whole engine raises up. Not cool The newer style can fail and the engine can't raise up more than the inner mount. Like I said, just my .02 cent.
You can pick up the later stands at pull-a- part cheap. Good luck. |
10-12-2011, 11:25 PM | #9 |
meowMEOWmeowMEOW
^^ torque straps
10-13-2011, 12:07 AM | #10 |
Still Learning
10-13-2011, 01:00 PM | #11 |
meowMEOWmeowMEOW
that sounds noisy.
I really want to get a set of torque/limiting straps for me engine once I've got the procharger setup done, but I will admit they don't look nearly as cool; as they would on something with a big bds sitting up top.
10-15-2011, 08:40 PM | #12 |
Put an F3 and gear drive on then! |
10-16-2011, 02:57 AM | #13 |
meowMEOWmeowMEOW
I can put an intercooled D1sc on it (or use meth) and change pretty much nothing but cam and tune. If I went that big it would be engine build time. Maybe someday.
10-16-2011, 03:48 AM | #14 |
In my experience...the towers you currently have on your frame are going to cause exhaust manifold/header clearance issues. If you run stock 72 towers and adapter plates, or 73 up towers and adapter plates, or the ece kit you would be good. I've done a 72 using the stock towers and adapter plates, along with the lsx swap headers. That was the best one imo. Also done a 71 and had to cut the tower up for clearance.
1969 Chevy Project SWB Fleet, 20s, 5.3, t56, in the weeds. 1970 Chevy Truck cab on a 1979 Jimmy frame-8.1 liter 496 bbc/sm465/np203-jeds doubler-np205/d60/14bff Welded/42 tsls on recentered H1s 1998 Chevy Crew Cab K3500 SAS'd with hpd60, links and swayaway coilovers. 8.1l vortec DD/towrig "I like long walks, especially when they are taken by people who annoy me. " |
10-16-2011, 10:00 AM | #15 |
The stock frame stands can fit nicely with the factory A/C on the LS using Doug Thorley headers. They were made for these trucks, so they look and fit awsome
