Old 10-10-2011, 12:04 AM   #1
kwin
kwin's Avatar
LS swap with hydroboost question
I recently purchased a 2006 5.3, a 700 r4, and a cable throttle body.So I have to order a flywheel spacer and motor mount plates and i'm ready to get going.
My 1990 CC is equipped with hydroboost and I would love to retain it. The pumps are not the same one has 3 lines (HB) and the 5.3 has 2 , has anyone ever dealt with this before?
Is this do-able?
Keith
kwin is offline   Reply With Quote
Old 10-10-2011, 08:16 PM   #2
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Re: LS swap with hydroboost question
the truck engines didn't all come with hydroboost pumps. My 6.0 had the hydroboost pump already on it, which has the correct 3 lines. IIRC they can be swapped out from another modern truck, you'd just have to buy the right pump.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 10-10-2011, 10:25 PM   #3
pat565
Keith
Thre are some GM flywheels that don't require spacers. I think that the th400 and the 700r4 are the same. If so, I have a new one here that I won't be using. I ended up using a 4L60E trans
I have an extra set of adapter plates too
pat565 is offline   Reply With Quote
Old 10-10-2011, 10:35 PM   #4
usmcchevy
Has more rust than truck...
usmcchevy's Avatar
You can use a non-HB pump, just T the return lines together.
1972 Custom/10 SWB, 4.8/4l80e
Build thread
LSx Swap FAQ index
usmcchevy is offline   Reply With Quote
