Springless Dana 60 Hi Steer Arms
Thought I would break this topic out from another thread I have. Looking into going to a springless setup on my Dana 60 Steering arms. It looks like I could just drill my arms and install a set screw and add some bronze bushings to replace the springs. This would save me from having to get another set of caps for $120
Any thoughts guys
1972 K5 Build - plans - LS3-6L80e-One Tons..... 1971 CREWMAX Build.....at body shop for couple more years ![]() |
Re: Springless Dana 60 Hi Steer Arms
i am facing the WD, and i was searching the forum for solution, what i need to know shall i keep the spring the plastic bushing or move to spring-less? knowing that most of my drive is on road.
I used wfoconcepts.com springless arms....zero death wobble
![]() here http://www.wfoconcepts.com/pr/Dana-6...3168/3462/3445 ![]() ![]() ![]()
1972 K5 MPFI454/Sm465/Np205/D60/14FFd/Re-Centerd H1s w/Swamper Iroks ![]() |
Grease Monkey
6600DURAMAX what steering arms do you have? Here are some ideas for you...
This is a great alternative solution depending on your arm design: http://www.ballisticfabrication.com/...it_p_1693.html Here are the arms I have: http://www.ballisticfabrication.com/...es_p_1246.html
Tow Rig: 2012 Chevy 2500HD CCSB LTZ Z71 4x4 Duramax Ultimate Offroad Build: 1978 Chevy Silverado K30 Crewcab Build Link http://67-72chevytrucks.com/vboard/s...d.php?t=654053 Mud Truck: 1972 Chevy Cheyenne K30 4x4, 468/400/205, D60/D70HD, 18" Custom Lift, 17x39" IROKs FOR SALE http://67-72chevytrucks.com/vboard/c...ton-4x4&cat=12 |
I have the BlueTroch Fabworks Arms, those caps would work kind of, BTF arms are made a little different. I am thinkg about just drilling out my arms and installing the set screw and a spacer (right now I have a hole where my spring sets up into) to preload the poly bushing I already have. Question
1.What size is the set screw in your arms? I think all the above would work and save me from sending $120 ish on new caps I am also calling BlueTocrh today and see if the make a solid cap with no spring hole
Certified Hobbiest
Here is another option...not as fancy as Ballistic, or BTF, but it gets the job done.
http://pirate4x4.com/forum/showthrea...ngless+dana+60 not too bad price-wise either. I was able to get a crossover arm (milled 10* and TREs) and cap shipped for $100. |
#7 | |
![]() Join Date: Oct 2002
1969 Chevy Project SWB Fleet, 20s, 5.3, t56, in the weeds. 1970 Chevy Truck cab on a 1979 Jimmy frame-8.1 liter 496 bbc/sm465/np203-jeds doubler-np205/d60/14bff Welded/42 tsls on recentered H1s 1998 Chevy Crew Cab K3500 SAS'd with hpd60, links and swayaway coilovers. 8.1l vortec DD/towrig "I like long walks, especially when they are taken by people who annoy me. " |
