Old 10-20-2011, 09:03 PM   #1
rjsdad
rjsdad's Avatar
Violent Shaking?
Hey guys, when the burb's in neutral and the clutch is pushed in everything's fine, but when the truck's in neutral and the clutch is out the truck shakes really bad. Has anyone ever delt with something like this so I know what to check?
Jeff
rjsdad is offline   Reply With Quote
Old 10-20-2011, 09:47 PM   #2
vectorit
What?
vectorit's Avatar
Re: Violent Shaking?
Something sounds like it has come apart.
Can you crawl under and see if the clutch pressure plate is at least still firmly bolted to the flywheel?
Maybe take a pry bar and give the flywheel a tug to see if it has started to come loose from the crank?
Just a couple thoughts at the moment.
Chris
1968 K20 Suburban
1972 K10 LWB PU
vectorit is offline   Reply With Quote
Old 10-21-2011, 12:44 PM   #3
rjsdad
rjsdad's Avatar
Ok. Thanks Chris. I'll get under the thing today and try to figure it out.
Old 10-21-2011, 11:42 PM   #4
Slinger60
Slinger60's Avatar
Could be the thowout bearing maybe....
1969 C10 LWB GMC.
1970 K5 Blazer
1971 K10 Burb
Build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=529970
Shawn
Slinger60 is offline   Reply With Quote
Old 10-22-2011, 12:51 PM   #5
rjsdad
rjsdad's Avatar
That doesn't sound good.
Old 10-22-2011, 01:28 PM   #6
Dunenutt
Newbee
Dunenutt's Avatar
That is the one part of a vehicle that scares the cr@& out of me! That clutch/flywheel will do bad things to trucks and people. Tear it down, and find the issue before it finds you.
Just sayin...
Dunenutt is offline   Reply With Quote
Old 10-22-2011, 08:55 PM   #7
Street Smart
Street Smart's Avatar
Could be the clutch disc coming apart, or the input shaft and or the input shaft bearing.
With the clutch depressed both stop spinning. Do you feel it when you drive?
1967 GMC Suburban, Supercharged 6.2 LS with a 6l80e , my 11 second tow vehicle! *pic in my profile*
1987 GMC CrewCab Dually 6.0 LS/6L90e, new tow pig.
http://67-72chevytrucks.com/gallery/...=74049&cat=500
Street Smart is offline   Reply With Quote
Old 10-23-2011, 04:58 PM   #8
rjsdad
rjsdad's Avatar
I don"t feel it when driving, just stopped in neutral with the clutch out.
Old 10-23-2011, 05:18 PM   #9
71gmcburb
71gmcburb's Avatar
Since it only does it when the trans is out of gear my money would be on th bearings in the front of the trans for the input shaft. when in gear both ends ar supported but iwhen out of gear one end hangs loose. pull the trans and with the gearbox in nuetral see if there is any slop in the input shaft. also gives you a chance to inspect the clutch pack. my 2 cents
a wise man once said "There are only two real rules to life...
1 - Don't sweat the small stuff
2 - Everything is small stuff
71gmcburb is offline   Reply With Quote
