Old 10-23-2011, 11:11 PM   #1
rayfinseats
Broken starter gear
Ok, so this all started with a dead Walmart battery, dragging, hard to start. Timing was a little high so I backed it off to about 4 degrees BTDC. Stock 350/4 bbl.
SO I go to walmart and they test the battery and it's bad so I get a new battery. 650 CCA. Same problem, hard starting. I get a rebuilt starter. Still hard starting. I solder the battery cable on the starter end and replace the batt cable end. Ground is new and solid. Grounds to block and body etc. Started fine before all this.
Tried rebuilt starter with/without one shim and new starter with no shims. I've never had to shim a starter before on a SBC.
SO I go buy a "new" starter. With a charger hooked up it started fine so I figure I had problem solved. Next day grinding somewhat again. The flywheel looks good. Anyway today the starter gear BROKE. ANy ideas WTF is going on here. 83 chevy k10 stagered bolt starter. 168 tooth? TH350 trans.
Should I replace the starter and add shims till the dragging sound stops?
rayfinseats is offline   Reply With Quote
Old 10-24-2011, 03:41 AM   #2
willett
Another Day, Another Dollar
willett's Avatar
Re: Broken starter gear
if you put the exact same amount of shims on that came off you should be golden. sometimes they get stuck to the bell housing or the old starter and you don't even know that they are there.
-78 K20 Cheyenne 454 long box, 4" lift, 35" MT's, '84 cab, '80 box
"its hip to be square"
willett is offline   Reply With Quote
Old 10-24-2011, 08:53 AM   #3
Chevy1TonFun
Grease Monkey
Chevy1TonFun's Avatar
Every starter has different manufacture imperfections. I'd add and take away shims until no more grinding.
Tow Rig: 2012 Chevy 2500HD CCSB LTZ Z71 4x4 Duramax
Ultimate Offroad Build: 1978 Chevy Silverado K30 Crewcab Build Link http://67-72chevytrucks.com/vboard/s...d.php?t=654053
Mud Truck: 1972 Chevy Cheyenne K30 4x4, 468/400/205, D60/D70HD, 18" Custom Lift, 17x39" IROKs
FOR SALE http://67-72chevytrucks.com/vboard/c...ton-4x4&cat=12
Chevy1TonFun is offline   Reply With Quote
Old 10-24-2011, 11:13 AM   #4
rayfinseats
What ever happened to quality and workmanship? I'll try more shims I guess.
Old 10-24-2011, 12:46 PM   #5
dammitmitchell
the pollock
dammitmitchell's Avatar
it's castin imperfections.. every molding is different..
i had my first shimmed motor the other day also .. ive had small blocks since day one.. (well day one for me.. over ten years ago..)
Jack of ALL trades, Master of none.. (but one... procrastination)
Army vet 02-08
RIP El Jay! Miss you brother!
http://67-72chevytrucks.com/vboard/s...d.php?t=343538
http://67-72chevytrucks.com/vboard/s...d.php?t=386042
dammitmitchell is offline   Reply With Quote
Old 10-25-2011, 03:39 PM   #6
LANDC
LANDC's Avatar
Once you have a starter happily installed always rebuild that starter. Re use the nose cone of that starter with that block. By doing this you already know how many shims it needs to be in its happy spot. I went through hell and back because I traded my old starter in as a core when it died. Furthermore, starters are relatively simple to rebuild.
Custom Vehicle, Custom Problems.
LANDC is offline   Reply With Quote
Old 11-02-2011, 08:12 PM   #7
rayfinseats
That's an idea too
Old 11-03-2011, 05:51 AM   #8
j.kirn
Adding shims to a starter is dropping the starter lower,they usually are not machined right so some maching by your own doing is requiredto bring closer to the flywheel. I would remove the solenoid and pull on the bell to see where it is hittting on flywheel
j.kirn is offline   Reply With Quote
