Old 10-28-2011, 04:24 PM   #1
chevy_man5
GMC's n H.D.'s too!
chevy_man5's Avatar
Pictures of 60-66 4x4 Suspension Please
I would like to see some pictures of your suspension setups for 60-66 4x4's.
Mine (see post #83 in thread below) just doesn't look like it is supposed to be that way. I didn't think of it last night, but will look in my manual when I get home.
The front coil spring mounts look like they may be stock, but one of them has part of the spring still on it, above the leaf springs.
The rear suspension looks all off. There are extra bump stops, and extra shock mounts, etc.
Thanks!!!
Jason
1960 GMC 4x4 Babe (the Blue Ox) - Build Thread
chevy_man5 is offline   Reply With Quote
Old 10-28-2011, 06:11 PM   #2
'63GENIII
'63GENIII's Avatar
Re: Pictures of 60-66 4x4 Suspension Please
I think that's where the rubber bumpstops go on mine. I will take a look and try to get a pic later.
Chris
'63 k15 long step
Vortec 7.4 - L29 Blackbear tune, Five 0 Motorsports injectors, Chris Straub Cam, NV4500, divorced 205
52" front and 63" rear spring swap
D44 / 14bff - disc axles
Milemarker 9K and 10.5K hydraulic winches
63" & B52 Spring Install http://67-72chevytrucks.com/vboard/s...ng+swap+thread
NV4500 Reverse Build Thread http://67-72chevytrucks.com/vboard/s...=reverse+build
L29 - 7.4 Vortec Build http://67-72chevytrucks.com/vboard/s...&highlight=L29
'63GENIII is offline   Reply With Quote
Old 10-28-2011, 10:21 PM   #3
chevy_man5
GMC's n H.D.'s too!
chevy_man5's Avatar
63GENIII I hadn't thought about that. I'll bet you are right. I don't recall seeing and bumpstops in the front end. I'll look in the morning.
I still wonder what the cut off spring is for.
Jason
Old 10-29-2011, 09:20 AM   #4
duallyjams
duallyjams's Avatar
The rear lift blocks are the correct factory for the 4x4 but its looks like some one has swap the rear hence the double shock mount and bump stops IMO.
James
63 GMC V6 4speed carryall
65 chevy swb bbw V8 auto
68 K20 327/4 speed, buddy buckets
2002 GMC CC Dually Duramax
64 GMC lwb 3/4 V6 4speed SOLD
66 GMC swb bbw buddy buckets SOLD
IG duallyjams
The only thing that stays the same is constant change!
duallyjams is offline   Reply With Quote
Old 10-29-2011, 10:21 AM   #5
'63GENIII
'63GENIII's Avatar
I read over your first build thread and looked at the pics again and I'd agree with DuallyJams that there was a rear swap at some point. The lower (unused) shock mounts on the rear axle are where my shocks mount on the '63 and my blocks don't have the "arm" that your shocks are mounted to. I'm no expert for sure but I've never seen those. In reading your build thread, you mentioned it was a plow truck so I think your guess that the leftover spring in the front WAS in fact some sort of overload seeing as it is a 1/2 ton and had a plow on it. I will try to get pics today although I may have to email them to you or pm them to you.
Chris
'63 k15 long step
Old 10-29-2011, 11:01 AM   #6
chevy_man5
GMC's n H.D.'s too!
chevy_man5's Avatar
Dually Jams and 63GENIII thanks for the info.
Pictures would be great GenIII.
The diff cover says "74 F@rd", so I wonder if the stole one from that. If they did, I will have to verify the front and rear have the same gearing.
Thanks guys!
Jason
Old 10-29-2011, 11:37 AM   #7
'63GENIII
'63GENIII's Avatar
I PM'd you. BTW, the rear D60 in my truck is from a '73 D***ge and the front 44 is GM. The divorced 205 that I just picked up is D***ge as well. Lots of mixin and matchin over the years!
Chris
'63 k15 long step
Old 11-02-2011, 08:40 PM   #8
argonaut
argonaut's Avatar
chevy_man5,
I put a some photos on here: http://jase-ace.com/public/photo/196...K10/Drivetrain that I recently took of the drivetrain and chassis on my 66 K10 pickup. You'll have to sift through them.
It is pretty much all stock, but the transfer case and driveshafts are not installed at the time. Some are of the front axle and some of the rear. Hope this helps.
Jason M. @argonaut62
1972 K5 Blazer CST, Turquoise
1966 K20 Short Fleet Pickup, Big Ugly
1964 C10 Short Fleet, Gertrude
2001 Porsche 911 Carrera
1996 Ford Bronco XLT
1980 Jeep Wagoneer
2008 Honda CBR1000RR
2005 Honda RC51
1981 Honda CB750C
No dis-assemble Johnny Five! No dis-assemble!
argonaut is offline   Reply With Quote
Old 11-02-2011, 10:31 PM   #9
chevy_man5
GMC's n H.D.'s too!
chevy_man5's Avatar
Thanks Jason! When I saw Jason M. on the bottom, I wondered how you knew my last name. Then I realized that was your signature.
I looked through your pictures. On #1297 the piece on top of your front springs is taller that the one on mine. Your bumps stops are right above that piece. Mine are on the back half of the spring.
You can see some of the helper spring? on the top plate on the drivers side too.
On picture #1301, our lift blocks are the same looking, but mine have the extra arm on the bottom for the shock mount.
Duallyjams stated earlier they were stock, and I did find one small picture in the manual that shows it too.
On picture #1303 it shows your shocks mounted to some brackets inside the frame rail. Mine are mounted to the center crossmember.
Would these possibly be differences from mine being a ’60, and yours being ’66?
Jason
Old 11-02-2011, 11:24 PM   #10
argonaut
argonaut's Avatar
Here's what I think (merely conjecture):
Front
I'm guessing there was a factory option for overload springs on the front. I say this because it looks like the bump stop brackets are riveted onto the frame rails. It wouldn't be uncommon for these trucks to have been purpose built for things like plows. With this option they relocated your bump-stops rear-ward and added the brackets for the coil...
Rear
Obviously your rear axle isn't stock. I think the lift blocks with lower damper mount, and the upper mount crossmemeber must be stock for the earlier models (I'm guessing 60-62, remembering that the 4x2 frames were a different "X" style these years). This is why the rear bump stops don't match up.
1980 Jeep Wagoneer
2005 Honda RC51
1981 Honda CB750C
Old 11-03-2011, 05:42 AM   #11
j.kirn
There are some minor differences in the 60-66 4by years. Your front is correct, rear axle is not stock,another thing i can point out is your transfercase shifter is to the right of your transmission shifter,this is correct for 1960 only.
j.kirn is offline   Reply With Quote
Old 11-03-2011, 09:07 AM   #12
chevy_man5
GMC's n H.D.'s too!
chevy_man5's Avatar
Thanks guys!
Unfortunately the rear end says '74 F@rd on the diff cover.
Where is Aerotruck? He will know if the overload was a factory option. He pulls info out of his library for just about anything on here!!
Thanks for pointing that out J.kirn! I hadn't noticed that.
I love this site!!
Jason
Old 11-03-2011, 09:46 AM   #13
j.kirn
There was no factory overloads for the 60-66 4bys
Old 11-03-2011, 12:32 PM   #14
argonaut
argonaut's Avatar
It should be pretty easy to pull a leaf sprung 12-bolt rear axle assembly out of a later model pickup and swap it in.
1980 Jeep Wagoneer
2005 Honda RC51
1981 Honda CB750C
Old 11-03-2011, 01:22 PM   #15
aerotruk63
Check The Champ, Demonstrator
aerotruk63's Avatar
Nacked front end. The rubber snubbers / bump stops are directly above the center of the front axle on this 64 Chevrolet K10 Canadian built frame of mine. By the way the 64 front K10 rubber snubber is the same as the C10 rear diff snubber on my 63. The snubber mount is to the outside of the frame.
Rear shock location. The rubber snubber you have on your front springs are the same as what I removed in the rear of the 64. They must have beaten the crap out of this truck every bump stop had bottomed out.
Old 11-03-2011, 01:32 PM   #16
aerotruk63
aerotruk63's Avatar
Timbren supplied GM with their rubber spring suspension enhancers in the early sixties. I spoke to Timbren and while they supplied the rubber springs they did not supply the brackets.
1964 GMC
My build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=397681
From the Timbren.com site. This is for the rear C10 which would be the equivalent for the K10 front though the bracket would have to be modified.
http://timbren.com/timbren-applicati...fs/GMRC10A.pdf
Old 11-03-2011, 01:49 PM   #17
aerotruk63
aerotruk63's Avatar
A hint of sarcasm in your post?LOL
Old 11-03-2011, 02:36 PM   #18
chevy_man5
GMC's n H.D.'s too!
chevy_man5's Avatar
No sarcasm!!!! Pure Envy!!!
You must have rooms full of books, and or hard drives full of files!
Jason
Old 11-03-2011, 09:53 PM   #19
aerotruk63
aerotruk63's Avatar
And no life! LOL can't wait to finish the season and get back to my stuff!
Info from the 1963 Chevrolet Truck Data Book. Notice the rear shock mounts in the bottom two pictures.
Old 11-04-2011, 08:30 AM   #20
chevy_man5
GMC's n H.D.'s too!
chevy_man5's Avatar
Thanks Aerotruck!!
On the first picture you posted there is an * by the text FLEETSIDE PICKUP MODEL K2534 with special snow plow equipment. Does that refer to the * on the second picture by the Custom Features?
I can see the shock mounts are like mine, so at least the '60 GMC and the '63 Chevy are the same setup… I think?
63GenIII e-mailed me pictures of his ’63 and it has rear shocks like the ’64 and ’66, but he also has a D@dge rear end in it too. I can't tell in the pictures he sent if there is the same crossmember that my shocks are mounted to. If it is OK with him I will post up his pictures here also, just for other people in the future to reference.
Your ’64 K10 and Argonaut’s ’66 appear to have the same setup, with the brackets on the inside of the frame rails.
Jason
Old 11-04-2011, 11:45 AM   #21
chevy_man5
GMC's n H.D.'s too!
chevy_man5's Avatar
'63GenIII said it was OK to post these for reference.
Jason
Old 11-04-2011, 01:26 PM   #22
aerotruk63
aerotruk63's Avatar
* I would say that is what it's referring to.
One thing though, in GM literature they would borrow off previous years illustrations and perhaps add a little detail pertaining to the subject at hand. The illustrations in the parts books require your discretion as well. While it may be information for 1963, the illustrations could be from the year to years previous.
In 63, Chevrolet created a lot of new parts into the C10. New engines, Transmissions and differentials, however the K10 retained the 235/261 and other parts. On top of that some parts were changed during the 63 production year thus when you read in the parts books there are early and late designations.
1964 had the new engines/diffs and transmissions from the two wheel drive line.
Old 11-04-2011, 01:36 PM   #23
aerotruk63
aerotruk63's Avatar
My old 62 K10, man I loved that truck. Rear shocks mounted transversely.
Old 11-04-2011, 01:47 PM   #24
aerotruk63
aerotruk63's Avatar
1963 Chevrolet Chassis Builders Book.
This book has a series of measurements for coach builders and other manufactures to go by when designing stuff to put onto stock Chevrolet trucks. See the shocks mount facing forward in the technical drawing.
Old 11-04-2011, 04:37 PM   #25
'63GENIII
'63GENIII's Avatar
Hey Jason thanks for putting those up! My shocks are mounted to the frame rails by way of a stud that's on a riveted bracket on the frame. They are both facing the same direction (foward) and are mounted to the axle the same as the original. In fact, I cut the lower mounts off the original axle and welded them onto the D60.
Aero. You say that the shocks on your '62 were mounted the same a Jason's? That '62 was pretty nice! Not to thread jack here, but did it also have a moonroof? Too cool!
Chris
'63 k15 long step
