Old 10-28-2011, 05:42 PM   #1
AirSpeed
AirSpeed's Avatar
72 front driveshaft interchange options.
I need a front driveshaft for my 72 GMC truck, do any other year trucks use the same or similar shaft?
AirSpeed is offline   Reply With Quote
Old 10-28-2011, 07:29 PM   #2
Mike C
Mike C's Avatar
Re: 72 front driveshaft interchange options.
Best bet would be same vintage, same transmission and t-case. Different transmissions and different transfers can make for different shafts. '73 and up trucks have more wheelbase and different location for the motor relatively speaking. I would consider having one made. A brand new CV style shaft runs about $300 balanced.
I just had to have one made for my '86 K30. Truck was originally an SM465/205 with a slip yoke on a one piece rear shaft. The replacement SM465/205 that came from an 80's Suburban required a two piece shaft with carrier bearing which was no surprise, but the front driveshaft was now 5" too long.
New shaft was $310 delivered from Wenco. This is the second shaft I have bought from them. First was a custom one for a Nissan Borg Warner T5 in my 240Z with a 1310 joint on the rear companion flange. Nice people to work with.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 10-28-2011, 08:45 PM   #3
odog
odog's Avatar
I have a 1978 Bronco with a c-6 and 205 tcase and the front drive line fits into a 72 chevy with a TH400 and an np205 tcase. It also fits a 67 and 69 chevy with a sm420 tranny and rockwell t221 tcase. Thos broncos are kinda hard to find around here, but the f 150s in 78 and 79 should be the same. Good luck.
1969 4x4
Nothing beats a good rock drill and some dynamite
odog is offline   Reply With Quote
Old 10-29-2011, 12:28 AM   #4
lukefalls
$50 bucks plus the ride from Alaska, you can have my old one. Its completely rebuilt. Make sure that your transfer case has a yoke and not a flange.
shoot me an e-mail at lukefalls@yahoo.com
Here is the link to my build:
http://www.pirate4x4.com/forum/showt...slow+gmc+build
lukefalls is offline   Reply With Quote
Old 10-29-2011, 01:29 PM   #5
AirSpeed
AirSpeed's Avatar
Thanks! I sent you an email, Aaron
Old 11-05-2011, 01:38 AM   #6
lukefalls
Aaron,
shipped!
Old 11-05-2011, 01:25 PM   #7
AirSpeed
AirSpeed's Avatar
Aaron,
shipped!
Thanks again! Nice smooth deal!
