04-17-2003, 02:52 AM | #1 |
Seatbelt ???
Will the seatbelts out of a 88- up full size truck fit our trucks? Can I use the original bolt location to hold it down?
1992 Gmc 2wd 1972 Chevy Blazer 2wd |
04-18-2003, 02:39 AM | #2 |
anyone
04-18-2003, 03:29 AM | #3 |
Yeah, I believe they will fit, I know there have been guy's on here who have swapped in the 88-up seats and seat belts- I think there are bolt holes inside the cab, (in the upper rear cab-pillar, with a little plastic cap on them) my truck has them, but I haven't pulled the caps off to see whats behind them, I hope to do this myself eventually one of these days......
1969 G.M.C 3/4 Ton 920 (Canadian Version) 307 3 speed, currently apart 1998 Chevy 1/2 ton ex cab V-6 5 speed 1967 Chevy SWB - project truck; not started just yet |
04-18-2003, 04:25 AM | #4 |
Designated A-hole!
Under the caps is a threaded hole. I am told it is 7/16 fine thread.
"If it ain't broke, fix it 'til it is!" Being stupid ain't illegal. We're Still Debt Free Except for the House!!! www.daveramsey.com 70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e 93 S-10 "Poppaw's Truck" |
04-18-2003, 02:48 PM | #5 |
I was wondering about the bottom part. Can you use the existing hole and drill another in the cab floor or do you have to drill 2 new holes?
05-01-2003, 02:47 AM | #6 |
anyone know if the how well the bottom lines up with full size chevy trucks seatbelts?
05-01-2003, 03:00 AM | #7 |
from the looks of the bottom seat belt assembly, any seat belt from newer trucks should bolt right in. may have to modify the plastic casing a little though
04 GMC Sierra RCSS 70 CST LWB 04 HD Sportster 1200 Custom |
05-01-2003, 03:28 AM | #8 |
I had to drill new holes in the bottom if I remember right and its important that they sit close to the way they did in the newer Chevs in order for the lock mechanism to work properly when you pound the brakes. I realize I need to get more pictures of my truck so that I can show some of this stuff. If I remeber correctly I got my belts out of a '92 , right color and all. krue is right about the top holes being threaded behind the cap. I had two bolts machined for me to fit that were of high quality steel so they wouldny snap off if I was ever in an accident.
CHIP327 67 GMC Pickup |
