Old 11-01-2011, 07:37 AM   #1
mud slut 350
mud slut 350's Avatar
1991 K30 4l80E or NV4500 behind Cummins?
So I have a 91 K30 which had the 6.2L in it. I bought the truck off a guy the truck had broke down on him and it was setting on the side of the road. I got his number from a note he left on the window saying not to tow will be removed shortly so i called him up myself. The trans was blown and only moved in reverse, barely. he said hed sell the truck for 500! No rust needs a fender engine ran great. x military truck d60 front! So i bought it off of him the truck sat for a while i kept it running though pulled the axles for my 82 and then sold the engine. Its setting in my driveway now with stick axles under it for now just to roll around. I want to put a Cummins in it and pretty much do a complete frame off make it a daily driver/Hauler. Im not sure what tranny to put behind it though. I want a stick so i was thinking the 4500 but was wondering if anyone has ever done that combo or not. I was also considering the 4l80E which is already in the truck id just need it rebuilt. or any other suggestions let me know! pics of swaps like this would be awesome too!
82 k10 350sbc, sm465, np205, dana 60 front 14 bolt ff rear 4 inch susp lift 33's aka "MUD SLUT"
2007 cbr 1000rr
mud slut 350 is offline   Reply With Quote
Old 11-01-2011, 08:39 AM   #2
b454rat
Re: 1991 K30 4l80E or NV4500 behind Cummins?
The 4500 came stock behind 94-up Cummins. I'm not sure a 4l80 can survive behind the 6BT, but IMO rather have the stick...save the t-case, it can be used behind it. The adapter is worth a small fortune...
2000 GMC CCSB 454/4L80 6” lift SAS
1999 Chevy CCSB 454/NV4500 6” lift
1999 GMC Yukon 350/4L60 4" SAS
Old 11-01-2011, 10:13 AM   #3
Redcap
NV4500 for sure.
Redcap is offline   Reply With Quote
Old 11-01-2011, 10:36 AM   #4
GCncsuHD
Charlie Daniels w/ a Tq Wrench
GCncsuHD's Avatar
I also would rather have the 4500, but for those that prefer an automatic, a 4l80E can be made to survive behind a stockish 6BT. It was even used in stock applications behind the LB7 and LLY Duramax in the vans (well 4l85e...) Although the dmax was detuned, plenty of van guys have ran stock truck LB7 and LLY tunes with good results.
ΜΟΛΩΝ ΛΑΒΕ
67 C10 Shortbed "Great Grandpa's Truck" I6 3 on the Tree 71k original miles 5.3 swap in the works
69 K5 Blazer-Family Beach Cruiser Project
78 K30 Dually Semi-Retired Fire Truck 350/SM465 35"s
SOLD01 2500HD ECSB 6.0 4x4 5.13's 8" lift 38"s
GCncsuHD is offline   Reply With Quote
Old 11-02-2011, 09:35 AM   #5
mud slut 350
Yeah it has a 205 behind it that i will swap to the 4500 if thats the route i go (which i probably will) because i want a stick in it i was just seeing what everyones feedback would be about the 4l80 but im thinking it will cost a pretty penny rebuilding it. Also thought the 8.3L cummins instead with a semi trans just for all out hey why not lol. A buddy of mine just picked up one pretty cheap to put in his excursion but im not sure i was thinking about the 24v 5.9 Cummins so i can downtune for better gas milage when im not doing any pulling
2007 cbr 1000rr
Old 11-02-2011, 10:29 AM   #6
GCncsuHD
GCncsuHD's Avatar
Sure why not
http://www.nc4x4.com/forums/showthre...084#post667084
ΜΟΛΩΝ ΛΑΒΕ
Old 11-02-2011, 12:30 PM   #7
snj8198
snj8198's Avatar
I would go with the stick as I love rowing the gears, but definitely use the close ratio NV4500 as it lends to be more user friendly with the narrow powerband of the diesel and moving a load.
-steve
Steve
1971 GMC Longbox. Full Roller Stroker 489 w/ FiTech EFI, Chris Straub Cam/NV4500/205/D60/14B w. Grizzly Locker and 4.11's. 2" Lift on 33's
snj8198 is offline   Reply With Quote
Old 11-03-2011, 05:51 AM   #8
mud slut 350
I like that link GCn that trucks awesome! mines a SRW though so prob wont be doin the 10 lugs lol wanna keep it low to pull a gooseneck or fifth wheel
2007 cbr 1000rr
Old 11-03-2011, 08:35 AM   #9
mud slut 350
anyone know if you can mate that fulmer 13 spd to a 24v cummins?
2007 cbr 1000rr
Old 11-03-2011, 08:38 AM   #10
mud slut 350
fuller my bad
2007 cbr 1000rr
Old 11-03-2011, 02:06 PM   #11
GCncsuHD
GCncsuHD's Avatar
Yes, easily, that build was a 13 speed Fuller behind a 6BT... There were plenty of trucks that came stock with Fuller transmissions behind the 6BT that will have the correct bellhousing.
ΜΟΛΩΝ ΛΑΒΕ
Old 11-03-2011, 03:57 PM   #12
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
The NV4500 will be the cheapest and easiest. The 13 speed fuller would be cool, but what a waste in a pick up. You'd get tired of shifting that thing for sure. Not to mention I'm sure it would suck to work on. I put a 8V92 and a 10 speed in a 86 K30 and it was a really tight fit. Sucked to work on once I got everything in there. The 4L80E can be built to handle it but will be expensive to get behind the cummins. You will need an adapter and flex plate, and a controller and a starter. Probabaly around $1700 just to get the trans mated to the cummins. If you want to go with the fuller, I do have one bell housing left that will work for one.
Ryan
1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread
1972 GMC Sierra Grande Longhorn 4x4
1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed
1972 C10 Suburban Custom Deluxe
1969 Chevy milk truck
1971 Camaro RS 5.3 BTR STG3 Cam Super T10
1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project
Tired of spark plugs? Check this out.
Dieselwrencher is offline   Reply With Quote
Old 11-03-2011, 06:29 PM   #13
Pyrotechnic
Pyrotechnic's Avatar
Originally Posted by Dieselwrencher View Post
I put a 8V92 and a 10 speed in a 86 K30 and it was a really tight fit. .
Not to thread jack but got any pics? That I've got to see. I've seen a 6V53 in a truck and that was a pretty tight fit. The bigger issue is the weight of the engine, how did you address that?
1977 GMC Sierra Grande
Pyrotechnic is offline   Reply With Quote
Old 11-03-2011, 06:54 PM   #14
Dieselwrencher
No pics sorry. I did this about 11 years ago before I got on the computer and forums and stuff. It was a very tight fit. As far as the front springs, I had some front springs out of a big Kodiak we retro'd at work and they were way over kill. The engine was in the K30 frame for about a year and I swapped the engine, and my trans on a military truck frame. I used the K30 body and it was much easier to work on it then. I sold the truck and it went to Nebraska some where.
Ryan
Old 11-07-2011, 02:56 PM   #15
nekkidhillbilly
truck is oem 4l80e truck that was oem diesel has the controller for the 4l80 already.
nekkidhillbilly is offline   Reply With Quote
Old 11-07-2011, 05:41 PM   #16
Dieselwrencher
That'll only work if you can transfer the proper inputs from the GM diesel to the cummins. The 4L80E needs throttle pos, and engine speed, and I'm not sure what else. You could make brackets and modify to your needs I guess. I haven't messed with a 4L80E behind one before. I have helped with a couple, but it wasn't as easy as use the stock ecm on the truck because the trucks didn't have them in them.
Ryan
Old 11-08-2011, 04:15 AM   #17
andrewmp6
Destroked sells adapter and flexplate to bolt a 6bt to a gm trans.
andrewmp6 is offline   Reply With Quote
Old 11-10-2011, 06:58 AM   #18
I like manual but the 4L80E would do fine. Are you sure it needs a rebuild?
Old 11-10-2011, 06:23 PM   #19
Dieselwrencher
Cummins makes one as well. But it has an offset built into it which I do not like. The Destroked parts are nice, but it makes it very expensive when installing any auto using their billet flex plate.
Ryan
