Old 11-01-2011, 11:21 AM   #1
Mt Man Chad
Mt Man Chad's Avatar
4X4 upper radiator hose p/n?
I've gone to Napa and a couple other parts houses.
If somebody has a chance can you get the numbers off your upper radiator hose. Auto parts stores keep giving me 2X hose that's about 4-5" too short.
Hope to start the burb today and this is the last thing I need.
Picture is thanks to Chris on his 68 4X4 burb, imagine this the same hose for 4X4 blazers ect ect.
68 CST SWB - Gold/White 50th anniversary /TH350/Buddy Buckets/3.73 Posi/dogdish caps.
68 K10 Burb - Gold/White 327/SM465/NP205/3.73 "Daa Burb" build thread
Mt Man Chad is offline   Reply With Quote
Old 11-01-2011, 01:21 PM   #2
vectorit
What?
vectorit's Avatar
Re: 4X4 upper radiator hose p/n?
I got that hose from one of the truck vendors.
It has the GM part numbers on it, not sure if it would help a parts counter guy.
Chris
1968 K20 Suburban
1972 K10 LWB PU
vectorit is offline   Reply With Quote
Old 11-01-2011, 02:38 PM   #3
bullington
All around good guy
bullington's Avatar
I just looked on mine and the numbers were worn off.
What I have done in the past is take a coat hanger and form it along the top of the hose and cut it to length. Measure the OD of both the thermostat housing and radiator attach point.
Then bribe the local napa or parts store clerk to rummage through the hoses till I get a match. Sorry I can't be more help.
bullington is offline   Reply With Quote
Old 11-01-2011, 06:58 PM   #4
john
member #16
john's Avatar
I thought 4x4's had steel tubes.
http://67-72chevytrucks.com/vboard/s...d.php?t=435358
john is offline   Reply With Quote
Old 11-01-2011, 07:09 PM   #5
vectorit
What?
vectorit's Avatar
Originally Posted by john View Post
You are correct, they did and mine had one.
It rotted out from sitting still for years, and just recently got a replacement.
Chris
1968 K20 Suburban
1972 K10 LWB PU
Old 11-01-2011, 10:54 PM   #6
Chesapeake
Dayco 70935. I've run that hose on a '72 k-10 and currently on a '70 Blazer. Fits like it belongs there.
Chesapeake is offline   Reply With Quote
Old 11-02-2011, 08:39 PM   #7
Mt Man Chad
I learn something everyday.....
Thanks!
