11-03-2011, 09:16 PM | #1 |
Chevy Lover Till The End.
What Drums Interchange
I'm runnin a '72 model 5-lug rearend in my '69 Chevy truck. I need to know what drums will interchange. I need the 5X5 bolt pattern & the correct brake size but a smaller outside of the drum to fit in a 12" wide aluminum wheel. I ground the fins & outside of my truck drum down a little so the wheel would go on but I would rather put another set of drums on, like off an Impala, Caprice etc.... I know if anybody would know it'd be right here. Thank you.
1969 Chevy SWB Big Block - Under the knife as of 12/26/2011 1989 Chevy Silverado, 4X4 - Daily Driver 1996 Chevy Suburban K1500 - 4-Wheeler, Campin Truck 1968 Chevrolet Impala Sport Coupe - 327/350hp, TH400, all original. Members I've met: BamaBaxter, My Build: http://67-72chevytrucks.com/vboard/s...d.php?t=500359 |
11-04-2011, 06:00 AM | #2 |
67-72 parts collector,…
Re: What Drums Interchange
Got any pics?
A 71-72 brake drum should work fine with any 15" wheel.
Tags |
drum brakes |
