Old 11-06-2011, 08:06 AM   #1
thirdstreettito
Resident of Here
thirdstreettito's Avatar
Opinions on tons swap?
I'd like to put tons under my 88 by next December. I also want a 7" lift and H1 beadlocks with 37's. Any ideas of what to do first, etc etc?
I was thinking of putting the D60(DRW)/14BFF(DRW from non C&C) under it and running a set of cheap wheels/tires. Then after I get all the stuff for the lift do the H1's and 37's. Or should I just collect all of the parts and do it all at once? Opinions wanted. I can save around $400/month. Thanks, Bradley
~Bradley~
2004 Black GTO LS2/T56 too much to list
Miss having a truck
thirdstreettito is offline   Reply With Quote
Old 11-06-2011, 09:06 AM   #2
ghettoluxury
ghettoluxury's Avatar
Re: Opinions on tons swap?
Gather the parts because you will end up doing everything 2-3 times and getting upset with your self and the project.
1949 Five Window, 1973 Step Side, 2000 Z71
ghettoluxury is offline   Reply With Quote
Old 11-06-2011, 09:16 AM   #3
Tons?...Oh.one ton axles,right? If I already had 8-lugs I'd swap axles,then lift or visa-versa. But,since you have 6-lug I'd gather everything and do it at the same time.
I'm in a similar situation with my '72 that I want to lift 6",put 37s on,and Dana60/HO52 w/4.10s. I have the axles,springs,shocks,wheels,and tires now. I want to go all through the front axle and don't really have the money to right now. I'd just lift it and do the front axle later but my present gears are 3.54s and the truck is an automatic. I doubt I'll even want to drive it until the axles/ratio are switched anyway. I'm tempted to just swap it all in and mess with the front axle once it's in. I'll have all the hard work behind me and the truck sitting how I want it,but I need to rely on it as a back up. So,I'm being patient and waiting until I get the time and the money to tear into the Dana60 first. I could just swap the rear and not use 4wd,but it really makes sense just to wait and have it right all at once. I've been waiting a looooong time and it sucks.
Old 11-11-2011, 05:04 PM   #4
modblacksmith
modblacksmith's Avatar
I'd wait and do it all at once, do the research figure out exatly what you want, buy the parts and assemble.
My D60 sat disasembled for three years and when I got it put back together I got in a huge rush to install it and lift the truck so I took a few short cuts and now I'm paying for it. I don't like half the things I did and now I have to take the truck apart and spend the money to do it right. I had 73-up front leafs arched to fit a 72, gave it almost eight inches of lift but they ride and look like crap.
Professional hot glue and pop cycle stick engineer.
72 K/20 soon to be C/10, 454, Th400, 9” rear.
01 GMC 2500HD 8.1, Allison, daily/towpig gas guzzler.
78 Bahner 19’ jet boat, 460 Furd turd.
modblacksmith is offline   Reply With Quote
Old 11-11-2011, 08:34 PM   #5
Chevy1TonFun
Grease Monkey
Chevy1TonFun's Avatar
Take your time and do it right the first time. Gather up your parts, it sucks I know looking at all the parts. I'd buy everything backwards to help with the urge to just do. Buy the wheels and tires, lift, then axles (unless you come across a sweet deal). Or you can save up the $$$ and then go buy it all. You can get H1 wheels and military 37" H1 tires for cheap from militaryoffroadtires.net.
Tow Rig: 2012 Chevy 2500HD CCSB LTZ Z71 4x4 Duramax
Ultimate Offroad Build: 1978 Chevy Silverado K30 Crewcab Build Link http://67-72chevytrucks.com/vboard/s...d.php?t=654053
Mud Truck: 1972 Chevy Cheyenne K30 4x4, 468/400/205, D60/D70HD, 18" Custom Lift, 17x39" IROKs
FOR SALE http://67-72chevytrucks.com/vboard/c...ton-4x4&cat=12
Chevy1TonFun is offline   Reply With Quote
Old 11-14-2011, 03:08 PM   #6
fun in dirt
fun in dirt's Avatar
Like everybody else said...get all the parts & then swap it. That way you can still drive it in the mean time.
'72 C to K20 "Cannibalizer" http://67-72chevytrucks.com/vboard/s...32#post8653432
'85 K30 "Big Nassy"
'01 2500 Suburban ...party wagon & tow truck
'06 Silverado SS...DD
'06 C1500 WT...DD
'07 Classic C1500 WT...DD
Built & sold cause can't keep 'em all:
'72 Blazer "The Bucket" http://67-72chevytrucks.com/vboard/s...d.php?t=433190
'55 Chevy straight axle gasser https://www.trifive.com/forums/showthread.php?t=173938
'69 Pro Street Chevelle http://www.chevelles.com/forums/showthread.php?t=332541
'86 M1031 CUCV http://67-72chevytrucks.com/vboard/s...d.php?t=553619
fun in dirt is offline   Reply With Quote
Old 11-14-2011, 09:08 PM   #7
thirdstreettito
Resident of Here
Thanks guys. Now, to do vortec heads/GMPP intake, then axles n such.
~Bradley~
Miss having a truck
