Old 11-10-2011, 12:34 PM   #1
chop_shop
69 K20 Power brake ?
I am picking up a 69 K20 this weekend. I have to put it back togeather. No problem. The price is right and most everything is there. The truck is all stock With closed knuckle front end. 4wheel drum. I dont mind the durm brakes. But i do want to put power brake on it.
What are you guys using for a booster and master? And what is need for install?
chop_shop is offline   Reply With Quote
Old 11-10-2011, 10:07 PM   #2
67mater
67mater's Avatar
Re: 69 K20 Power brake ?
should have bought mine; already power! A manual master should swap onto a power booster, but you will need a 67-72 booster or the bracket isnt right for the 67-72 firewall. Autozone reman booster is $105, and reman booster/master is $109!! what a joke. anyways, add $18 or $35 respectively if you dont have a core. just make sure master is for drum/drum if you replace it too.
time is inversely proportional to money; that's why it takes me so long
1967 K10
1967 Camaro
67mater is offline   Reply With Quote
Old 11-11-2011, 10:32 AM   #3
chop_shop
Thanks man. I probly should have.
Does the 67-72 booster take a bracket or is it just bolt on to the firewall?
Old 11-11-2011, 03:12 PM   #4
eric67m
eric67m's Avatar
Here is member LIVRAT's FAQ for power brakes. Both the thread and he are exremely helpful. I hope this helps.
http://67-72chevytrucks.com/vboard/s...d.php?t=214559
67 K10, lwb, fleetside, 327, 4spd, 205, cab and 3/4 frame swap, 14 bolt, big window, and a "rustoleum roll job"
eric67m is offline   Reply With Quote
