11-12-2011, 08:50 AM | #1 |
Gear shift indicator
Anyone know which aftermarket company I could find a factory appearing replica shift indicator on the column for my suburban for a 4 speed auto overdrive, like a 700r4 or 4l60e? P R N O D 2 1 instead of the P R N D 2 1.
I want to keep the factory look, and I'm sure I have seen them before, I just cannot for the life of me remember who makes them. And my search efforts on the forum appear to be insufficient. |
11-12-2011, 12:57 PM | #2 |
Re: Gear shift indicator
I believe all the big companies making repro parts for our trucks have an OD selector dial available. Brothers, LMC Truck, Classic, etc. There is also Ididit, who has a line of aftermarket steering columns, I think they carry selector dials too. It will probably say PRND321, with a circle around the D, rather than the way you have written it. I need one for my Burb, but I'm looking to add OD to my truck, so I'm holding off on a selector dial for mine until I upgrade the tranny(th400 to 700r4 I hope).
Good luck with your search Ken in Cleveland |
11-12-2011, 01:10 PM | #3 |
Sorry to hijack the thread, but are you guys using te stock column? How do you get all of the gears when it's really a 3 speed and not 4?
1972 C10 Deluxe.Shortbed. 402/400. A/C, white interior, needs complete restore. Project Red, white and blue. Used to be a Longbed apperently. http://67-72chevytrucks.com/vboard/s...d.php?t=451950 1971 c10 step 250 3 OTT 1969 c30 TOW-MATER. 307 4 speed, holmes 440 body. http://67-72chevytrucks.com/vboard/s...d.php?t=451082 2006 CTS-V LS2 6spd. |
11-12-2011, 02:41 PM | #4 |
I guess I thought the number of stops was determined by the tranny at the end of the linkage, not the steering column itself...? I could certainly be wrong. Someone more knowledgeable should chime in at this point...
11-12-2011, 05:27 PM | #5 |
The detents are on the linkage inside the transmission
11-12-2011, 08:58 PM | #6 |
Detents are in the tranny, same amount of range, just an extra detent. LMC truck did not list a overdrive indicator. I do expect it to have a circle around the D, but there is no key on they keyboard to represent it. I will check brothers and the rest. I do not want to swap columns as it is a factory tilt.
11-12-2011, 09:08 PM | #7 |
Brothers had what I was looking for, Thank You.. Next question, where could I buy more ambition?
