Old 11-13-2011, 10:35 PM   #1
67mater
67mater's Avatar
WANTED your stock 4x4 parts!!!
Anybody putting a lift on and gonna scrap their old rear leaves? I need em! Looking for 3/4 ton rear leaves. even 2wd will work, but must measure 26" from pin to either end (center of eye) along the leaf = 52".
Also need a stock steering arm from a corporate. 3 bolts unevenly spaced. I can get a pic.
thanks!
time is inversely proportional to money; that's why it takes me so long
1967 K10
1967 Camaro
67mater is offline   Reply With Quote
Old 11-13-2011, 11:43 PM   #2
lukefalls
Re: WANTED your stock 4x4 parts!!!
Call WFO Concepts. I'm sure they've got a used arm
www.WFOConcepts.com
lukefalls is offline   Reply With Quote
Old 11-19-2011, 12:19 PM   #3
67mater
67mater's Avatar
somebody has to have torn a 3/4 ton down; ive seen a ton of lifts on here!
1967 K10
1967 Camaro
Old 11-19-2011, 12:29 PM   #4
powerdriver 1958
Kid's Mechanic
powerdriver 1958's Avatar
Please post your WTB here http://67-72chevytrucks.com/vboard/c...cat.php?cat=19
powerdriver 1958 is offline   Reply With Quote
Old 11-19-2011, 12:29 PM   #5
67mater
67mater's Avatar
there's never any traffic there! I wanted the 4x4 guys.
1967 K10
1967 Camaro
Old 11-19-2011, 01:14 PM   #6
jrdv
jrdv's Avatar
You will have trouble finding stock leaves due to using a cutting torch to get them off. I have replaced the originals on 4 3/4 ton trucks and had to cut them off because I couldn't get the bolts out. The rubber bushings seize up on the bolt and there is no other way to get them out.
jrdv is offline   Reply With Quote
