11-18-2011, 07:57 PM | #1 |
1972 C20+10 Upgrade
Ok here we go day one of my 72's upgrade. The plans for this portion of the trucks restoration is converting it from a c20 to a c30 with help from a set of split ring rims from a 65 c30 and some stepside fenders. Im also step notching the frame for the axle flip and a air springs helper over the axle. for the towing im installing a 5th wheel reciecer on the step notch and a hidden hitch in the rear along with fully boxing the rear frame rails and setting up a rear fuel tank and driver side saddle tank to get the tank out of the cab... stay tuned!
Oscar |
11-18-2011, 07:59 PM | #2 |
Re: 1972 C20+10 Upgrade
Here im getting the axle centerline so it wont look funky with the wheel not centered in the wheel well
11-18-2011, 08:02 PM | #3 |
once the the point of the axle ceterline was transfered to the frame, off with the bed.
11-18-2011, 08:06 PM | #4 |
here i started stripping the frame rails..
11-18-2011, 08:11 PM | #5 |
There it is bare frame! other than all the brackets that need to be removed. The rear end is getting the blue toch fab Kryptonite DIY diff cover and a reseal and posi inspection...
11-18-2011, 08:18 PM | #6 |
Well... almost catastrophic failure on my part i started lifting the the truck with the lift and i guess the 402 is a heavy bastard cause my baby almost did a front flip lol, i ran my fat ass the to rear and jumped on the frame to bring it back down and had a friend hand me a couple of the wheels to weigh it down enough to put the jack stands under the front.
11-18-2011, 08:31 PM | #7 |
And there she is, put away till monday morning when she gets put on the frame bench. I did pretty good worked on it from 8 to 12:30 this morning. oh and sorry about the fuzzy pics, on this pic i figured out the camera settings..
11-19-2011, 04:40 PM | #8 |
looks good man
11-19-2011, 09:54 PM | #9 |
I wish my truck looked as good as yours. Do you have a photo of your rear bumper bracket and how it attaches to the frame? I just got a C20 myself and want to put a rear bumper on it but can't seem to figure out how to get the brackets to work on it.
Good luck with your conversion |
11-29-2011, 06:22 PM | #10 |
Well decided to do the frame work on the ground this is what i got done yesterday finnished the passenger side step notch i will metal finnish it when i box the frame rail, for now im moving onto the drivers side.
1972 C20 BB402 1987 3/4 2WD 350/SM465 (soon to be shortbed) 1975 1/2 4wd shortbed 350/SM465/NP205 Big "O" Last edited by BigO61; 11-29-2011 at 06:28 PM. Reason: mis spelling |
12-03-2011, 05:16 PM | #11 |
great progress man
12-03-2011, 05:42 PM | #12 |
Looking good. So, you are going low, with the ability to tow...right?
Best Regards, Leon M. Instagram: @TheDirtyDianah
Bagged | 6.0L LS | T-56 (6-Speed Manual) | Turbo Burnout/Rolling Video: Chevy C10 Stepside 6.0L LSx & 6-Speed Manual |
12-06-2011, 07:08 PM | #13 |
yeah im going as low as i can and still tow
1972 C20 BB402 1987 3/4 2WD 350/SM465 (soon to be shortbed) 1975 1/2 4wd shortbed 350/SM465/NP205 Big "O" |
12-07-2011, 07:14 AM | #14 |
Love it
12-07-2011, 08:11 AM | #15 |
Collector of Projects
I hear horrible things about split rims... maybe someone more familiar with the issues will chime in...
12-07-2011, 10:48 AM | #16 |
This is going to be a great project. The building of the Blue Mule
1968 Chevy C/10 LWB V8 1983 K5 Blazer 1989 C1500 Stepside Reg. Cab V8 |
12-10-2011, 07:55 PM | #17 |
12-15-2011, 09:21 PM | #18 |
well i got the the truck assembled and been driving it for a couple days now,, heres the last couple things i did before i pulled it out of the shop.
The 5th pic down has my step side fenders i picked up in stockton for $100 for both on CL.
1972 C20 BB402 1987 3/4 2WD 350/SM465 (soon to be shortbed) 1975 1/2 4wd shortbed 350/SM465/NP205 Big "O" Last edited by BigO61; 12-15-2011 at 09:53 PM. Reason: added discription |
12-15-2011, 09:35 PM | #19 |
67-72 parts collector,…
Looks good.
What's next?
12-15-2011, 09:47 PM | #20 |
Well the whole boxing and step notch i did with 3/16 plate and the cross bars are 2x3 250 wall, i had some custom "U" bolts bent the truck had 5/8 and i upgraded to 3/4 since the weight is gong to be supported by the them and the helper bags im putting over the axle, and the u bolt plate i bent with an Iron Worker and it 3/8 plate.
I tried to use most of all the mounting tabs shocks brake lines ect. for now untill i blow the truck apart to build it without a time restriction. not too bad for 10 days of 6 hours... enjoy, oscar
12-15-2011, 09:59 PM | #21 |
Next is the bed alterations with the stepside fenders, and i picked up a frontcross member from a 85 chevy 3500 with drop spindles and drop springs hub to hub for $300. but for the hollidays ill be cruisin it around BTW i cut 2 coils out of the front to try to level it but now it has a rake! until i bag the front... more to come mid jan
12-15-2011, 10:02 PM | #22 |
i like the name "Blue Mule" but im changing the color to the original med olive met or....?
12-19-2011, 02:19 PM | #23 |
Well howdy mister! we're gonna have to meet up sometime with our trucks! i gotta see yours in person soon lol, i'm still here in sac so let me know! - mitch
1970 C/20 4x4, 350, sm465, np205(She tipped over... total rebuild from the frame up!) ya gotta keep on keepin' on, Life's a garden, dig it! |
12-19-2011, 02:23 PM | #24 |
Cool man!!!!
