Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1960 - 1966 Chevrolet & GMC Pickups Message Board > 60-66 Suburbans
Old 11-19-2011, 05:30 PM   #1
Crazy Rusty
Crazy Rusty's Avatar
65 Burb body mounts
Did a quick search over the forums and didnt see any posts about this so I thought I would ask...
Took the body off the frame a few weeks ago and most of the body mounts were toast. Does anyone know a source for a pack of new ones? I found a few places that sell 67+ but they're all round, looks to me like the 65s have to be rectangle in some places just to fit where they need to go. Any ideas?
Thanks!
Crazy Rusty is offline   Reply With Quote
Old 11-19-2011, 06:34 PM   #2
padresag
Re: 65 Burb body mounts
classic industries has them listed as 69-72. the earlier ones supecedes up to 69-72 and was used up to about 2000 in blazers
ron
padresag is offline   Reply With Quote
Old 11-19-2011, 09:22 PM   #3
RoyL
RoyL's Avatar
ron
sorry to hi-jack, but will be looking for same. Don't see on classic industries website the mounts you are referring to? http://www.classicindustries.com/truck/parts/g2423.html
1965 Suburban
Waiting on Time and Money
RoyL is offline   Reply With Quote
Old 11-19-2011, 09:29 PM   #4
Crazy Rusty
Smile Re: 65 Burb body mounts
I was wondering the same thing but I think I am going to get the pack of rounds and see how it goes. I generally buy from lmc so I'm going with this kit - http://www.lmctruck.com/icatalog/cb/full.aspx?Page=37. We'll see how it goes
Old 11-19-2011, 09:36 PM   #5
Crazy Rusty
ron
Thanks for the response Ron, I think that got me going in the right direction.
Old 11-19-2011, 09:52 PM   #6
RoyL
RoyL's Avatar
Which kit? Part # 30-0131 BODY MOUNTING KIT-70PC?
1965 Suburban
Old 11-19-2011, 09:54 PM   #7
rustyrodknocker
If you do go with the later model round ones. please report back on how they fit.
rustyrodknocker is offline   Reply With Quote
Old 11-20-2011, 12:10 AM   #8
padresag
http://www.classicindustries.com/truck/parts/g2423.html are the ones.
there are specific measurements for these. they do mount top and bottom and the tabs interlock to keep them in position. you need 16 of them
ron
Old 11-20-2011, 03:24 AM   #9
dthela
dthela's Avatar
The frame holes on the burbs are 3 different sizes, I used the 69 mounts but had to use rubber hose in some to make up the difference check your frame.
dthela is offline   Reply With Quote
Old 11-20-2011, 06:20 PM   #10
RoyL
RoyL's Avatar
ron
1965 Suburban
Old 11-20-2011, 08:42 PM   #11
padresag
By rondavid at 2009-12-30
pics of suburban-panel body insulators
Ron, this is Lewis. Please forgive me for not getting back sooner, but I have been busy in my work for the church I serve. I checked both my 65-66 parts manual and my 67-72 parts manual. This is what I discovered: 1964-6 body mounts are p/n 3794779, w/dimentions of 1.76" w; 3.00" l; 0.92" thick, needing 8 (up & lwr same). The 67-8 p/n is 3909351 up & lwr, 69-72 uses 3909351 as the lwr, but p/n 3946246 is the upr. No dimentions are given for these cushions, and it seems that the frame changed in '69. Qty's in 67-8 are 16, with 69-72 requiring 10 of each. If you have dimentional axcess to the later cushions, these 64-66 dimentions should help you. Like you, I suspect that the 67-8 cushions will work, but there is no superseded p/n's between the body styles. I can tell you that years ago I bought cab mounts for my 65 and the p/n's had superseded to the mounts for the 67-72 cabs. I hope that this info is of some assistance in answerring this question.
the dimensions sound right. the .92" high includes the raised section around the bolt hole.
The measurement excl the raised section is between about .73-.74" high
hope that helps
ron
you can see one that is partially collapsed in the top right
I did some follow up on these insulators and the 3946246 is still a good # from gm. it is stocked in Lansing, mich. it is on the discontinued list though. list at about 25.00 each. they were last listed as the #3 upper body insulator on a 73-91 blazer/jimmy. classic industries has them for 13.00 each and look under 69-72 suburban
ron
they work on the 64-66 suburbans
padresag is online now Report Post Reply With Quote
Old 11-21-2011, 04:03 PM   #12
Crazy Rusty
Thats the one I bought. I put the body back on the frame (without mounts at the moment, had to get it off the rotisserie) so as soon as I get them in I'll attempt to install them and take some pics.
Old 11-21-2011, 05:27 PM   #13
padresag
classic ind. also shows a 67-72 suburban mount kit and if it works is less money than buying the rectangular ones singular. I thaink that the frt cab mounts are different than the 60-66 one though
http://www.classicindustries.com/tru...ts/34149g.html
ron
Old 11-21-2011, 05:37 PM   #14
padresag
it would be the way to go if one knew if they fit(looks basically as the one 67-72 kit from classic ind.). it would be good if one could get measurements of the g=height of the upper insulators and what size that they are where they fir into the corresponding holes in the frame mounts; but you could always modify that hole to work properly
ron
Old 11-22-2011, 07:18 AM   #15
Carryallnuts
I used the 69-72 style. The holes in those are larger, so I enlarged the holes in the steel frame mounts. I then made a steel spacer, just like original, but the same diameter as the 67-72 mounts. I made 10 all together, but 2 of them were longer than the other 8. In retrospect I would have installed them without the extra trouble of making spacers. I don't see them moving once they are installed and tight and I could have glued them down. Or I would have gone to a place in El Cajon, Cal. that sells everything and anything rubber and I would have made my own. They are a little over 9/10 of an inch with a vulcanized piece of rectangular steel that is 1/8 of an inch thick. I played around with making urethane ones but i did not like how rigid they were. Mine's a 4x4 so I wanted a bit more flex and I was afraid that it would create stress cracks in the body. For the front ones you can use truck mounts and you are 20% there.
Carryallnuts is offline   Reply With Quote
Old 11-22-2011, 08:08 AM   #16
RoyL
RoyL's Avatar
ron
Extract from Shop Manual. Just so I'm clear, the cab mounts (#1 and 2) for Burbs and pickups are the same, round biscuit type? And the rear mounts are the rectangular style, #s 3, 4, 5, and 6?
"Panel and Suburban
The number 1 and 2 body mounts of all Panel and Suburban vehicles are as shown in Figure 4. Mounts typical of numbers 3, 4, 5, and 6 of these vehicles may be seen in Figure 5."
1965 Suburban
Old 11-22-2011, 05:03 PM   #17
Carryallnuts
I believe only the first mount is "truck style" as the second steel frame mount sits lower on a Sub vs. truck. Makes sense since the Sub has the lower floor for seating.
Old 11-22-2011, 05:19 PM   #18
padresag
only the pictured nbr 1 is used . in figure 5- panel and suburban body mount the one with the letter A is actually the "B" pillar insulator which is in the same position as nbr 2 mount in the above fig 4 illustration.
in the fig 5 illustration the separate view "A" is the suburban mounting while the other is panel mounting as the panel floor goes up right behind the seat and the suburban allows for a footwell as the back floor is shorter
ron
Old 11-22-2011, 07:46 PM   #19
dthela
dthela's Avatar
but the bolts and holes in the frame, are different sizes depending on location
Old 11-22-2011, 07:47 PM   #20
dthela
dthela's Avatar
second mount near rear step in burb is rectangular type.
Old 11-22-2011, 08:25 PM   #21
padresag
[QUOTE=RoyL;5024174]Extract from Shop Manual. Just so I'm clear, the cab mounts (#1 and 2) for Burbs and pickups are the same, round biscuit type? And the rear mounts are the rectangular style, #s 3, 4, 5, and 6?
only the frt mount that lines up with the "A" pillars is round. the other 4 insulators towards the rear are all rectangular.there are only 5 mounts in total down each side
ron
Old 11-24-2011, 01:05 PM   #22
dthela
dthela's Avatar
my old mounts notice differences in thickness and square versus rectangular
Old 11-24-2011, 01:06 PM   #23
dthela
dthela's Avatar
new versus old
Old 11-24-2011, 01:58 PM   #24
padresag
Don;I have taken 4 sets out and they have all appeared to be the same, though they are off the 64-66 vintage. earlier ones may have been different.
ron
Old 11-25-2011, 12:24 AM   #25
dthela
dthela's Avatar
i got what i got lolol. the narrow ones went in a spot where there was little clearance. I remember grinding down one side of the mount about 1/8 of an inch to get it to line up. maybe i'll get under her and take some pics of the install. i have a 60 burb for parts, i've never been under to compare.
