Old 11-26-2011, 04:03 PM   #1
brook-71k5
tire size
I just bought a 71 blazer with a 2 1/2" lift (31" tires). the previous owner was planning on putting 33's on the truck, however i like the look of 35's. does anyone know if 35's will fit on a 2 and 1/2" lift or will i need to change the lift? thanks
brook-71k5 is offline   Reply With Quote
Old 11-26-2011, 04:40 PM   #2
AJs72K5
AJs72K5's Avatar
Re: tire size
With 35's, you're looking at 4" if you plan on staying on the street, 6" if you're going to be doing an sort of offroading with it.
- AJ
Gray Matter Build - 1972 K5 with some stuff
AJs72K5 is offline   Reply With Quote
Old 11-26-2011, 09:56 PM   #3
BLUE THUNDER
BLUE THUNDER's Avatar
Re: tire size
Yup, exactly what AJ says. I've got a 4" lift and tried my brothers 35's on and they were pretty snug. I put my 33's back on.
BLUE THUNDER is offline   Reply With Quote
Old 11-27-2011, 12:10 AM   #4
bouncytruck
SKINNY TIRES RULE!
bouncytruck's Avatar
Re: tire size
I'd say stick with the 31's for a while and see how you like it. I've had two K5s with 35's and I like the way the skinny 31's ride on bouncytruck the best. My second rig was running 35's with a 6" lift and it had a ton of bump-steer.
You may be looking at regearing if you step up to 35's too.
bouncytruck 1972 K5
The Hauler 1994 K1500 Suburban
The Daily2010 Kia Soul
Wife's Ride2014 Fiat 500L
bouncytruck is offline   Reply With Quote
Old 11-27-2011, 11:16 AM   #5
woodchk502
Re: tire size
I agree as well. My 72 is stock and currently runs 33s and they had to create a little room for themselves up front the last time I had her out.
jim
woodchk502 is offline   Reply With Quote
Old 11-27-2011, 11:48 AM   #6
Firebirdjones
Re: tire size
I run 33's on mine with the stock ride height and haven't had a clearance issue at all. We off road in the mountains as well.
I never was interested in raising mine, (too old to climb in with 33's and stock ride height that issue is bad enough I like the ride, no bump steer issues either. Being a daily driver has alot to do with my decision making too. If it were a toy I'd probably lift it.
Besides, raising it up would probably hurt the gas mileage catching more wind, not to mention blowing me around the highway up here in windy Prescott. Things are shaped like a brick
No way 35's would fit without a lift though. If you are set on 35's I'd take AJ's advice.
Firebirdjones is offline   Reply With Quote
Old 11-28-2011, 02:50 AM   #7
joemacho
joemacho's Avatar
Re: tire size
it depends on how wide the wheels are ive gotten away with a 32 x 12.50 x 15 with a 15 x 12 rims with no problems only driving in the street.
1972 gmc jimmy project comin soon ( jus a sin )
1959 chevy apache shortbed fleetside (brsgrm)
1966 Chevy c30 duallie 2wd (big chief)
joemacho is offline   Reply With Quote
Old 11-29-2011, 05:37 PM   #8
SamMargritz00
SamMargritz00's Avatar
Re: tire size
the way i've always been taught was 33's with 4 inch lift, 35's with 6, 37's with 8, etc. thats the way i've always done it with my vehicles.
SamMargritz00 is offline   Reply With Quote
Old 11-29-2011, 08:09 PM   #9
Firebirdjones
Re: tire size
I've always been one to see what works for myself. I guess I like to experiment
I did the 33's with stock lift, and it works great. I had heard of clearance issues but I tend to think there are other things going on that people may not take into consideration, and why it works for some and not others.
Possibly wrong backspacing on the wheels. Less backspace would kick the tires out further, and I could then see it might be an issue with the front fenders.
Possibly the 40 year old rubber body mounts and core support mounts are sagging with age or moving around under stress, causing fender clearance problems.
Possibly 40 year old springs that are sagging??
I took care of 2 of those things before I did the swap. First, I installed poly body and core support bushings (stock height) as well as poly bushings in front and rear leaf springs.
Secondly I made sure I had as much backspace as I could fit on the front. That turned out to be 3 3/8" in my case. Anymore backspacing caused interfearance with the outer tirerods.
I'm still running the OEM issued 40 year old leaf springs, so it's even possible that my blazer might be a tad lower than new.
Still the 33's clear with room to spare.
Old 11-30-2011, 07:39 PM   #10
SamMargritz00
Re: tire size
in the first pic i have 4 inch lift with 33's on my 72. the second is my 82 chevy with 6 inch lift and 35's. i suppose its personal preference. ive seen 2 inch lifts with 33's and 4 inch lifts with 35's.
Old 12-02-2011, 09:49 AM   #11
Yukon Jack
Post Whore
Yukon Jack's Avatar
Re: tire size
I threw my 69's 35" tires on my 70 K5 with a 4" lift for a few days when I had the 69 out of service. These tires didn't rub at all on my 69 when it had a 4" lift but they did rub on my 70 with it's 4" lift - I guess it shows that different 4" lifts definitely do result in different actual lift amounts.
Here is a pic when I had the 35"s on my K5
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 12-02-2011, 06:56 PM   #12
Firebirdjones
Re: tire size
You got away with it but your bottom front fenders are wacked.
I'm thinking most guys here (including myself) are trying to avoid that little modification. From the looks of yours, it appears to me you would have had more than enough clearance without wacking the fenders.
