Old 11-29-2011, 08:10 PM   #1
yz426tony
1970 K20 Axle Swap
Hi guys,
I have a 1970 K20 longbed with the eaton axle and leaf springs. I am wanting to convert to either a corporate 14 or a Dana 70. My question is, are there any specific years i should be looking for? Is there a year/model that is a direct bolt in?
Thanks!
yz426tony is offline   Reply With Quote
Old 11-30-2011, 12:46 AM   #2
lukefalls
Re: 1970 K20 Axle Swap
Use a 14 Bolt from a 73+ 1 ton. If you use a 3/4 ton, you'll have to move the spring perches.
Just FYI, the Eaton is a better rear end.
Read:
http://www.pirate4x4.com/forum/showt...highlight=ho72
lukefalls is offline   Reply With Quote
Old 11-30-2011, 01:28 AM   #3
72LSK10
72LSK10's Avatar
I used a 14BFF from a 75 K20 and it worked out fine, had to cut and replace my perches due to pinion angle but it was easy.
72LSK10 is offline   Reply With Quote
