Old 12-02-2011, 04:25 PM   #1
trapperjack
trapperjack's Avatar
62 K10==many parts swap questions
I'm going to pick up a late 70's drivetrain this weekend. Matched front and rear axle, t350 auto trans and married t-case. All steering stuff except column, but includes pump and hoses etc., steering componenets still attached. Crossmemebers, etc, all included.
from a late 70's Blazer. Has the auto-locking hubs, though. Questions are...
Is this likely to be a 203,205, or 208 transfer case?
Will a turbo 350 trans mount to a 62 235 6cyl?
How hard to retro fit a power steering box and pump to a 62 with a 235?
Who had the power brake/clutch seperator stuff for sale on here? Capt. someone, I think. The new front is disc.
What else am I missing or not thinking about? U-bolts different? Spring perches? Shocks? Who's done this?
Thanks.
1962 Chevy K10 factory 4x4 stepside longbed
http://67-72chevytrucks.com/vboard/s...d.php?t=494632
1967 Chevy 3/4 ton 4x4 long bed (Henrietta) traded
1968 Chevy 1/2 ton panel wagon, V8 and powerglide
http://67-72chevytrucks.com/vboard/s...d.php?t=483345
1978 Ford F250, beater stepside
2008 Jeep Wrangler 4 Door
2010 Chevy 4x4 plain jane work truck
trapperjack is offline   Reply With Quote
Old 12-02-2011, 04:44 PM   #2
'63GENIII
'63GENIII's Avatar
Re: 62 K10==many parts swap questions
I've swapped the axle on mine to early 72-73 ish axles. I had new u bolts made which was pretty cheap and they made them in 20 minutes while I waited. The spring perches were the same but I did have to cut the shock mounts off of my stock axles and weld them onto the rear D60 and they work just fine.
I would guess that you might be able to find PS brackets possibly off of a later GM I6 that would work. They seem pretty interchangeable (the serpentine drive that I've got on the '69 396 is from a '97 454).
Not sure about the clutch separator, but I would try to grab the booster, brake pedal arm, pivot and pushrod and see if that could be made to work.
All of it took a little bit of fabrication but nothing serious... I'm not exactly a rocket scientist.
Chris
'63 k15 long step
Vortec 7.4 - L29 Blackbear tune, Five 0 Motorsports injectors, Chris Straub Cam, NV4500, divorced 205
52" front and 63" rear spring swap
D44 / 14bff - disc axles
Milemarker 9K and 10.5K hydraulic winches
63" & B52 Spring Install http://67-72chevytrucks.com/vboard/s...ng+swap+thread
NV4500 Reverse Build Thread http://67-72chevytrucks.com/vboard/s...=reverse+build
L29 - 7.4 Vortec Build http://67-72chevytrucks.com/vboard/s...&highlight=L29
'63GENIII is offline   Reply With Quote
Old 12-02-2011, 05:31 PM   #3
'63GENIII
'63GENIII's Avatar
I just found this in the 60-66 section. May be helpful? Hope I linked it right.
http://67-72chevytrucks.com/vboard/s...d.php?t=496595
Chris
'63 k15 long step
Old 12-02-2011, 05:45 PM   #4
'63GENIII
'63GENIII's Avatar
Chris
'63 k15 long step
Old 12-02-2011, 08:48 PM   #5
trapperjack
Ha! Me either. I'm, as my signature implies, a trapper. Love these old trucks, though. Thanks for the link. If I do the trans. swap, won't need the seperate clutch and brake stuff, but will need the brake booster stuff. not sure which way I'll end up going, but thinking the 350 auto and married t-case might be shoe-horned in.
Anyone know if the 235 I6 will push the 350 auto with enough power to get out of it's own way? Or if it will even bolt up or adapt so that a dumb old country boy can do it?
