Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > The 1973-1987 Chevrolet & GMC Pickups Parts Board
Old 01-23-2002, 08:22 AM   #1
fabricator
Post can I put 4 wheel drive train on 2 wheel drive frame?
I've got a 78, 3/4 ton 4 wheel drive and a 87 2 wheel drive was wondering if i could put the 4 wheel drive stuff on the 2 wheel drive frame with out much difficulty , since the 78 frame is rotted. your help is appreciated.
fabricator is offline   Reply With Quote
Old 01-23-2002, 10:51 AM   #2
crossy
Oh,you can't buy that new
crossy's Avatar
Post
YES,best way I saw to do it was grind the heads off the rivets of all the brackets you need from the 4X4,[front suspension]and drive them out . when installing on the new frame don't cheat ,use high quality bolts of grade 5,[3 hash marks on head],or better.watch the length of rear springs as there were some differences.just take a good look at everything you need FIRST so you know what you are up against. DAVE
with all the rocks that I turn over I should be finding more than slugs!
"been there, done that, ruined the T-shirt".
2007 LBZ GMC Sierra, ECSB
2006 LM7 RCSB Silverado
98 Vortec project.
94,3500,6.5L 4L80
81 SWB GMC POS finally gone
73 Pinto, stock, w/CragarSS's-eww
LOTS of Cummins trucks.
crossy is offline   Reply With Quote
Old 01-24-2002, 08:33 AM   #3
gchemist
BAD BOW-Silverado XST
gchemist's Avatar
Talking
Which cab do you plan on keeping? The hump is probably different to accomodate the tranny and 4X4 casing. If you just swaping frames you should have no major problems. If you grind the rivets you're in for a long haul. Just use a nice big chisel, vice grips and a good size ball peen hammer. The rivet heads pop right off with a good whack. I would nothing but grade 8 bolts and better.
Gerardo
1983 Custom Truck
TX Plates: "BAD BOW"
http://www.geocities.com/abetterchemist/
Gerardo a.k.a. Mad Chemist
Silverado XST videos
gchemist is offline   Reply With Quote
Old 01-24-2002, 08:49 AM   #4
fabricator
Post
i thought about a 3 ' body lift since i am using the two wheel drive cab. so what you guys are saying is that the frames are the same other than the 2 wheel and 4 wheel bracketry? are the 4 wheel drive holes in the 2 wheel drive frame?
Old 01-24-2002, 04:53 PM   #5
gchemist
gchemist's Avatar
Post
fabricator,
I know the frame rails at the front are cut different. You may want update the front clip to a 81+model. I would ask these guys http://www.coloradok5.com/tech.shtml
4X4 is not one of my best areas. The guys at Colorado can tell you for sure.
Gerardo
1983 Custom Truck
Old 01-27-2002, 10:23 AM   #6
crossy
crossy's Avatar
Post
Seeing that you are a 'fabricator' that frame diff in the front will be no problem for you . it is only done diff on the very front of the frame horn for bumper mounting . As I recall MOST of the holes are already there. grade 5 bolts are at least equal to the factory rivets. grade 8 are aircraft grade and kinda overkill . i buy grade 5 cheap at a farmtractor store where as grade 8's can be very difficult & expensive to buy.DO NOT BUY STAINLESS.IT DOES NOT HAVE THE SHEAR STRENGTH NEEDED. I know you shouldn't put a price on safety and I wouldn't ,so I say grade 5 are fine.even a 2' body kit will clear the hump from what I remember but the hump from the 4X4 cab is easy to transfer to the 2WD also.I TOO was employed as a fabricator for a number of years along with certs in welding. DIG INTO IT! DAVE
[This message has been edited by crossy (edited 01-27-2002).]
98 Vortec project.
94,3500,6.5L 4L80
