12-15-2011, 02:35 AM | #1 |
Non-maglite flashlite suggestions?
i've given up (for now) on fixing the maglite due to time constraints.
Do you have any suggestions for any decent non-maglite, hopefully non-metal flashlights? i'm asking about non-maglite due to the swelling battery problem which i have not figured out how to fix at this time. 1) Money no object. 2) Money an object---say $30 max. 3) i would consider rechargable----either the light itself or the batteries. 4) Why is the $4.99 for 2 Eveready LED flashlight package at home depot worth $4.99? Because i got it only about a month ago and i here am asking the above question about decent flashlghts now. |
12-15-2011, 11:11 AM | #2 |
Re: Non-maglite flashlite suggestions?
I've got 2 maglites with the same problem as you. If money is no object......Streamlights are the way to go. I just got one of these.
http://www.ebay.com/itm/Streamlight-...item1c2072f5ad
James '68 Stepside (ground up in progress) My 68 build thread http://louisianaclassictruckclub.fre...side-t956.html '81 SWB "Pap paw" (Driver) The 81 build thread http://louisianaclassictruckclub.fre...-swb-t960.html Member of www.louisianaclassictruckclub.com https://www.facebook.com/groups/296290610747732/ |
12-15-2011, 03:21 PM | #3 |
Depending on amount of use I would suggest getting a decent LED faraday flashlight. I got tired of having dead batteries and for no more than I use it, it works perfect.
May look a little odd shaking a flashlight but you won't ever have to remember to change the batteries and the LEDs don't take too much power. |
12-15-2011, 04:22 PM | #4 |
This is my most used Flashlight. Use it in the garage, camping, hunting, everything. Runs off of 3 (AA)'s I change them once a year (opening of hunting season)
Cabelas XPG Headlamp This is a good one as well if you dont want a headlamp XPG Cree Flashlight You can find cheaper, but I have had great luck with the Cabelas XPG line as far as performance and quality vs price. They usually have the headlamp above on sale for $19.99 this time of year, but havent see nit lately at that price. Look for a light with CREE technology around 80- 120 lumens and you should be happy. I like 120+ lumens for the woods, 80 ish for closer stuff like around the truck (less glare)
"Lifetime" 72 C10 Project |
12-15-2011, 08:32 PM | #5 |
i use rechargeable streamlight http://www.streamlight.com/product/product.aspx?pid=153
i love it base comes with 2 batterys and a car charger, life time warranty
David fuller Ase Certified Mechanic Click here to help support our board!! 1971 Chevy c-10 under going a 4.8l LSx swap Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305 2007 Honda Accord my daily 145kmiles 2002 Honda Accord 4 door With 330k(sisters car) 2005 toyota Avalon 228k( brothers car) 2002 Sububran 5.3 245k 2000 Tahoe 5.3l 378 General manager for Marco's Carwash & lube |
12-15-2011, 08:39 PM | #6 |
Newbee
12-15-2011, 09:16 PM | #7 | |
Fuzzy |
12-15-2011, 09:42 PM | #8 |
As a man who has lost, broke or thrown away many a flashlight I highly recommend the Streamlight Stylus Pro. It uses two AAA batteries and has a life of 6.25hrs per battery change. I have the bigger Streamlight rechargeable but it has taken a backseat to this one. It is just as bright as a full size Maglight and I can clip it inside my pocket! It is just at $30 on the MAC tool truck.
Nick Carter 1967 C10 Short bed Fleetside Project Cheap Thrills! 2WD C10 Modern/Performance Alignments Easiest Alignment Ever! |
12-15-2011, 09:43 PM | #9 |
67-72 parts collector,…
Pelican.
We use these at my work. Best flashlight in my opinion. They have them in a ton of styles and sizes. http://www.pelicanproducts.us/p.Peli....LED.2410.HTML
12-15-2011, 09:52 PM | #10 |
i love my stream light owned it for 2 years and i droped it like everyday and the rear button broke and they sent me a new button free
12-18-2011, 11:24 PM | #11 |
x2 on the stylus pro. use it on a daily basis for over 2 years.
12-19-2011, 02:54 AM | #12 |
There is also a Streamlight Microstream. It uses 1 AAA. it is advertised to run 2.5hrs but I have personally used mine for about 75% of 2 12hr shifts. It has a built in pocket clips and also a hat clip.
Here is a link to it. http://www.streamlight.com/product/product.aspx?pid=144 |
12-19-2011, 06:40 AM | #13 |
I've used Mag-Lites for about 40 years. They were first called Kel-Lights. I have only had a problem with swollen batteries in one light that I let batteries go dead in and didn't remove. It's bad to eave dead batteries in anything,so I blamed myself. I guess I love them so much because they were the "only" flashlight worth having for many years. It's good to see there are other quality flashlights made now. Maybe I'll try one sometime,but haven't had cause to switch yet. I don't any like L.E.D. lights I've used. They've all put out a blue beam and I need white to see best. Do these lights mentioned put out a good white beam?
12-19-2011, 08:41 AM | #14 |
I use a streamlight stinger almost every night, our cars are also equipped with 5.11 tac lights. Both are LED and rechargeable. I would recomend eith one.
12-19-2011, 09:45 AM | #15 |
I used the Microstream before I got a Stylus Pro. They are the same light except the Pro uses an extra battery. They may have a different bulb but I'm not sure. In a professional setting I felt like the batteries lasted about two weeks, which to me is a long time.
Nick Carter 1967 C10 Short bed Fleetside Project Cheap Thrills! 2WD C10 Modern/Performance Alignments Easiest Alignment Ever! Last edited by BMERDOC; 12-19-2011 at 09:51 AM. |
12-19-2011, 06:47 PM | #16 |
Surefire G2 is on the $30ish range.
12-19-2011, 07:19 PM | #17 |
#16876
Nebo Redline. It takes three AAA batteries not expensive rechargeable ones. and puts out 220 lumen's and they are only around 25 bucks. You'll find that the magnetized end holds it to the underside of the hood quite well.
Posted via Stationary Device '71 Custom Deluxe C-20 402. '67 Buick Special 455. '49 Plymouth Special Deluxe. "I love that old car smell" Some people are like Slinkies... not really good for anything, but they still bring a smile to your face when you push them down a flight of stairs. |
12-20-2011, 01:59 PM | #18 |
The new Stylus Pro C4 used the same LED as the Microstream C4. You can get both in a non LED. Both the Microsteam and Stylus Pro put out a white light not blue.
12-22-2011, 08:54 PM | #19 | |
#16876
12-22-2011, 11:10 PM | #20 |
My Stylus Pro about 6' out on white siding...can't get much whiter!
