Old 12-15-2011, 08:42 PM   #1
86customdeluxe
86customdeluxe's Avatar
Transmission taking awhile to engage
i have a turbo 350 transmission, every gear takes awhile to engage. Having me to rev the engine so it will engage.. but after awhile or maybe a drive around the block i can park it and crank it back up and then works like "gold" literally. and fluid is perfect, im gonna change the gasket and filter ASAP, im sure it needs it. but if thats not the fix then what could it be?
hoping my transmission is not failing, i would rather pay a costly bill to get it repaired and not have to replace it.
please share your experience with me on this issue!
cant drive 55
86customdeluxe is offline   Reply With Quote
Old 12-15-2011, 09:49 PM   #2
big10ratrod77
big10ratrod77's Avatar
Re: Transmission taking awhile to engage
check your fluid level and smell the fluid if it has the smell of burnt pop corn you should probly drain the torque conveter, and the trans and add a new filter.
"gold"
if you have metal fileings your in big trouble...
77 chevy BIG 10 350/sm465/12bolt w 3.73 bout 240 horse power NO power steerin
79 chevy 1/2 ton 250/three on the tree/3.08s soon to get built 250/floor shift conversion/3.08s
81 mercedes 300d 25 MPG
77 chevy BIG DOOLEY 454/sm-465/14 bolt 4.10s "fully loaded"
73 plymouth duster 225 slant six/230 3 speed/8 1/4 trying to acheve 300 horse six http://www.cardomain.com/ride/3135091
'77 chevy trucks. built to stay tough.
life is short build a hot rod
big10ratrod77 is offline   Reply With Quote
Old 12-15-2011, 10:10 PM   #3
Goldfinger
Goldfinger's Avatar
Sounds like low pressure to me some fluid and a new filter should remedy it
1985 C10 Custom Deluxe LWB 305/700r4 [ Goldfinger ]
1999 k3500 crew cab dually 6.5tdi/4l80e
Goldfinger is offline   Reply With Quote
Old 12-15-2011, 10:22 PM   #4
motornut
78K & 79C Jimmys
motornut's Avatar
seen that when the vac line gets loose on the regulator
aside from that
i've used duralube for the tranny with good results
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
motornut is offline   Reply With Quote
Old 12-15-2011, 11:11 PM   #5
INSIDIOUS '86
INSIDIOUS '86's Avatar
happened to me before, maybe just low on fluid or an internal leak on a seal that seals up when the trans gets warm
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac
3''spintech prostreet mufflers xpipe 1 3/4 headers
build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217
Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511
INSIDIOUS '86 is offline   Reply With Quote
transmission, turbo 350, turbo 350 transmission
