12-15-2011, 09:49 PM | #1 |
Driveshaft Question: 1 piece or 2 piece?
'69 SWB 1/2 ton
Just got through with the c-notch and front/back airbag install. With the standard crossmember, do I need to be thinking about a 1-piece driveshaft or can I just stay with the stock 2-piece setup? Worried about the pinion angle geometry? Anybody think this is a concern? Obviously hoping the stock setup will be OK, an all new 1-piece is going to be $$$$ Thanks guys. |
12-16-2011, 04:59 AM | #2 |
Re: Driveshaft Question: 1 piece or 2 piece?
I have two trucks
1st with c-notch, bags and a 2 piece drive shaft 2nd with c-notch, bags, and a 1 piece drive shaft and both work just fine with out any problems. but maybe im lucky?
My Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=442487 My Picture Gallery http://67-72chevytrucks.com/gallery/...0&ppuser=36004 |
12-16-2011, 09:38 AM | #3 |
Florida Edition
We have a guy in town that builds drivelines for a living and he recommended I stick with the 2 piece on my big block short stepper. I wanted him to make me a one piece, he had been down that road many times and thinks the stock setup is a better design for my truck.
This advice cost him money so I have to believe he knows what he is talking about.
70 GMC Short Stepside "Rose"-An American Beauty: Factory 402/TH400, AM/FM, AC, Tilt, Tach, Buckets, Posi, PS, PB, 3-5 Drop, Complete Resto-Rod 67 C-20 Slant Back Wrecker "Mad Max" 67 C-10 Ratrod "Step-N-Wolf" 71 Serro Scotty Sportsman camper "Scotty" 97 LT1 Z28 "The Hornet" Link to more pics of "Rose" http://67-72chevytrucks.com/vboard/a...p?albumid=1684 Check out my "Cheap Tricks" thread and add to it if you can, lots of good info there. http://67-72chevytrucks.com/vboard/s...d.php?t=489394 |
12-16-2011, 02:51 PM | #4 |
on a short wheelbase, I'd go with the 1 piece driveshaft
12-16-2011, 02:58 PM | #5 |
WHY..................can you give a Good Reason?
Measure with a yard stick Mark with Chalk Cut with a torch Built it yourself, don't count on others to to do it for you or with you. It will never get done |
12-16-2011, 03:24 PM | #6 |
Fabricate till you "puke"
The swb truck has a short enough shaft, to run a 1 pc unit....& as long as you have the room for a larger tube shaft(you need that on a 1 pc), I would agree with Larry. My reasoning is that you have less parts, & less ANGLES to play with(less headache to setup) If the truck is "layin rail", you might be better off with a 2 pc (for clearance through the crossmember). Personally, I would run a 1 pc shaft in my longhorn....if I could (no go due to lenght tho). crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
12-16-2011, 03:30 PM | #7 |
Junior Member
I have changed all my trucks to a one piece shaft.
71 Suburban 350/700R4 Project Trixie 72 CHEVY,Highlander,SWB,396,T400 |
12-16-2011, 03:43 PM | #8 |
There's a dozen good reasons, some of which are presented above.
I'd use a one piece any time I could get away with it. Less complexity, fewer moving parts, fewer angles, less mass, usually less cost (from an OE perspective) etc. The factory did a two piece in some applications to keep the prop rpms below the prop critical speed - the speed at which the drive shaft begins to bend and swing like a jump rope. It is determined by vehicle top speed capability, shaft material, tire size, rear axle ratio, overall system resonances - and the availability of pre-existing parts. Use of a two piece design was a compromise (ie, suboptimization) right from the drawing board. In the aftermarket you/we don't have the same constraints relative to material and diameter, so - if it was me - I'd have a one piece shaft made using whatever it takes. Steel, composite, aluminum, metal matrix - whatever - and at whatever diameter was required to cover my anticipated vehicle top speed. K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ Last edited by Keith Seymore; 12-16-2011 at 03:58 PM. |
12-16-2011, 03:48 PM | #9 | |
I see this all the time on the boards, where guys will go to all kinds of modifications (engine transplants, trans swaps, frame modifications, suspension reworks) and then ask: "what driveshafts are out there that will fit?". Any shaft I've ever had made was two or three hundred bucks, to make one from scratch. Why would a person do all that work, spend all that money on high tech modifications, and then want to use a shaft that they found buried in the dirt somewhere or out of somebody's beater? Really? Spend the incrementally few more bucks and have a new shaft made. Sorry if this sounds curmudgeonly - a stage I am looking forward to, btw - but I'm being sincere here. K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
12-16-2011, 04:06 PM | #10 | |
Larry Only said "on a short wheelbase, I'd go with the 1 piece drive-shaft" He never state any concern as to why. I'm always Entertained by statements with no reason.... I'm actually Entertaining the Idea of having one made for my truck.
12-16-2011, 09:12 PM | #11 |
I have been watching this thread. I am at an impass. I have a 69 c-10 cst that was originally a BB truck. I bought it without a motor or tranny. I put a 350 in it with a NP833 4 speed trans. I am down to the driveshaft. I found one, and went to se what needed to be done to make it fit. The wheel base on the truck is 127in. It came up bout two in short. I the started looking for a longer slip yolk. Could not find one. So I went to a Driveshaft Shop. He had a longer slip yolk. While talking to him I priced a new Carrier baring....ie.. all to have him rebuild it and balance it. Well he pulled out the carrier bearing, and it had a different mount than the truck had. He looked further and couldn't find anything different to match what I described. So I know I have to have a 2 piece driveshaft, I need a carrier bearing, and will have to have a front driveshaft made to fit. All that does not bother me. But.... The mount on my cross member bothers me. I took some pics. and if someone could identify exactly what I have. Are the carrier bearing mounts different for a 1/2 ton than a 3/4 ton? The pic shows that the Factory rivets are still in place, the carrier braring mounting bracket doesnt appear to be hackd on in any way. I'm darn confused.
12-16-2011, 09:35 PM | #12 | |
it looks like to me you have a "horseshoe" type carrier, my 69 has the other kind the "round" type..
The two most important lessons to wrenchin'-1.The only time you have too much fuel is when you're on fire-2. If something hasn't broken, it's about to-- |
12-16-2011, 09:41 PM | #13 |
Cool... anyone got any pics of the "horseshoe" type and thier bracket?
12-16-2011, 09:41 PM | #14 |
here is a pic i hijacked from autozone website horseshoe type
the other is the round type im not sure whats better but im sure someone will chime in..
12-16-2011, 09:43 PM | #15 |
part numbers from autozone...
Part Number: HB88107A Alternate Part Number: HB-88107-A Application: Horseshoe type ----------------------------- Part Number: HB206FF Alternate Part Number: HB-206-FF Application: Round type
12-16-2011, 10:01 PM | #16 |
i just took a couple quick pics my '72 short step i'm restoring here at home. it has been lowered with 3" springs and a 1" block , ece delux track bar that give ya another 1/4" and i run a one piece driveshaft , without any issues oh , ive got a 400 short tail trans , which i see is leaking out of the yokes weep hole again ...
'70 k-10 longbox- mid 70's drivetrain 350/350 487x heads 10.1:1 flowmasters ,35's 3.73's auburn posi ,rear shackle flip. '72 short stepside U.S. forestry truck, '73 455 buick,400 turbo,dropped 2"-4 1/4" ,3.07 posi,:'89 silverado 1500 ,OK truck ,5.7 holley tbi ,trick 700r4 3.07 auburn posi ,and my '66 skylark ,'73 centurion and my '84 monte carlo imca stock car |
12-17-2011, 01:22 AM | #17 |
I tried to have a 1-piece shaft built for mine (72 lwb 350/350 C10 leaf rear), driveline shop thought they could do it. On lift at full droop driveshaft hit bottom of crossmember it goes thru. My options at that point were modify crossmember or stay with 2-piece shaft, I stayed with 2-piece. Apparently some of these trucks they were able to convert to 1-piece without mods, not mine.
12-17-2011, 08:56 AM | #18 |
Thats great information. I looked up the carrier bearings, both are available at Autozone. Does anyone have pics available that are using the Horseshoe type bearing? It just looks like something is missing. I know on the later Chevy trucks. Ie..75.... have a bracket that attaches to the crossmember that the carrier bearing bolts to. I guess what I am asking, does the 69 model use the same type mounting bracket?
12-17-2011, 07:45 PM | #19 |
Anyone with any pics? I went to ORileys and bought both kinds of carrier brarings. The Horseshoe one did not fit the driveshaft. The round type did. The only problem is that it does not fit my bracket.....Any ideas?
12-21-2011, 12:29 AM | #20 |
1961 crewcab
I thought the 2 piece design was due to wheelbase length more than anything else...at a certian point 1 piece wont work? -or is not optimum?
that said if you have to get one made anyway, (shorten your existing) I think a 2 piece would be a good idea on a lowered vehicle, it would solve any clearance problems with the rear x member... I was thinking of using one on my lowered 50 chev convertible , so I wouldnt have to cut up the rear driveshaft floor tunnel
60 build: http://67-72chevytrucks.com/vboard/s...d.php?t=280904 61 crew build: http://67-72chevytrucks.com/vboard/s...d.php?t=646830 63 build: http://67-72chevytrucks.com/vboard/s...d.php?t=336537 64 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=448681 65 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=590715 65 build: http://67-72chevytrucks.com/vboard/s...d.php?t=281955 |
