Old 04-22-2003, 04:00 PM   #1
1972ChevyGuy
1972ChevyGuy's Avatar
Bench To Bucket
What all needs to be changed on a 72 c10 lwb to go to bucket seats? (besides the seats of course) :P
1972ChevyGuy is offline   Reply With Quote
Old 04-22-2003, 07:26 PM   #2
CPNE
Resident Curmudgeon
CPNE's Avatar
Don't mean to be a smart a$$ but are you talking about the OE buckets that were originally installed in trucks? If so, it's really a matter of drilling holes to bolt the seats and console down. You should also reenforce the floor where you bolt it with a large washer or such. When I did this I used the outboard front hole used by the bench brackets as a guide and marked and drilled from there. The bucket brackets are shorter than the bench ones so you need to drill for the inner front and the inner and outer rear holes on these brackets.
Currently on or near the homestead:
67 Chevy SWB 2WD stepside 350/3 on tree (Pat's)
67 GMC SWB 2WD Fleet 402/auto (Brian's under construction)
67 Chevy 3/4 ton 2WD 402/auto (Business Hauler)
67 Chevy 1 ton dually 2WD 396/4 speed (Former business hauler, Needs TLC)
68 Chevy 1/2 ton Suburban 2WD 250 six/3 on tree (Brian's Needs TLC)
70 Chevy 3/4 ton 4WD 350/4 speed (Pat's - Disguised as a 68 GMC)
71 Chevy SWB stepside (Crushed by tree - parts donor)
72 Chevy 3/4 ton 4WD (Parts donor)
72 Chevy 3/4 ton 4WD Suburban (Parts Donor)
72 GMC 3/4 ton 4WD 292 six/4 speed (Mine - Disguised as a 67 GMC)
81 GMC 4WD Dually Dump Body 350/4 speed (Business Hauler)
82 Camaro Z/28 355/Super T-10 (Pat's toy)
93 Caprice 9C1 (Brian's Cop Car)
02 Toyota Camry (Reliable but a souless steel and plastic hulk)
2011 2SS RS Camaro M6 Factory Hurst Shifter
Maybe I need to sell some of this crap
Yet another Bozo with a sawz-all
CPNE is offline   Reply With Quote
Old 04-23-2003, 12:50 AM   #3
bpmcgee
bpmcgee's Avatar
CPNE implied, but didn't say outright that you'll also need the seat BRACKETS.
Just being redundantly redundant.
Brian
bpmcgee is offline   Reply With Quote
Old 04-23-2003, 09:31 PM   #4
1972ChevyGuy
so basically its just bolting brackets to floor, drill a few holes and pop them in?
Old 04-23-2003, 09:39 PM   #5
Gene
Gene's Avatar
Yep, but you wanna make sure the drivers side is lined up with the steering wheel. I am not being a smartass I made the mistake of being about an inch off after I drilled the holes, I now have an extra set of holes
1971 SWB 4X4 Build
BOARD MEMBER #5448
BOOMER SOONER!!!!
Gene is offline   Reply With Quote
Old 04-23-2003, 09:42 PM   #6
tom hand
CCRider
tom hand's Avatar
If you are talking about the stock buckets and console that came in these trucks... yep. If you are talking about using buckets from something else, it gets to be a little more fun. I installed these buy just drilling a few holes and bolting them down.
72 GMC Sierra SWB almost finished---- 84 Softail
Olive Branch MS
tom hand is offline   Reply With Quote
Old 04-23-2003, 09:49 PM   #7
Jackal2k9
Jackal2k9's Avatar
i still think the 99 chevy truck seats are the best buckets out there. Not only do they fit nicely but they have built in sholder straps. ive got pics posted in here somewhere of them.
Jackal2k9 is offline   Reply With Quote
Old 04-24-2003, 05:32 PM   #8
jer
I am currently installing s-10 seats in my '67. Well i will be when i figure out how i'm going to mount them. They are mounted currently through wood blocks so i know how high i should make the brackets but i don't really know where to go from there. Has anybody done this, has any ideas?
'67 Chev lwb soon to be daily driver
'68 Mustang 390 gt/California Special full(very slow)restoration
'77 T-Bird retired due to 400cid
jer is offline   Reply With Quote
Old 04-24-2003, 09:49 PM   #9
Bowed
those seats look pretty good
Tom , are your seats the same has the low back buckets used in the 73 + blazers ?
Bowed is offline   Reply With Quote
Old 04-24-2003, 10:08 PM   #10
dinnut
dinnut's Avatar
my buckets
i just got my truck monday but my buckets were attached to pieces of wood. cheap ass way. my truck is in pretty bad shape though.
70 longbed
496/th400/Ford 9"
dinnut is offline   Reply With Quote
