Old 12-16-2011, 11:34 PM   #1
Shortie
Junior Member
Shortie's Avatar
Key on power during crank
Im just finishing up wiring on my 69 lq4 swap and have noticed that i loose key on power during crank, I tried the ignition switch from my other 69 and same thing. Just wondering what everyone is doing to solve this
Shortie is offline   Reply With Quote
Old 12-17-2011, 12:54 AM   #2
usmcchevy
Has more rust than truck...
usmcchevy's Avatar
Re: Key on power during crank
Where are you getting your "trigger" for your key on relay? On mine I replace the stock red resistor wire that went to the coil with a normal 14ga wire and it keeps power during crank.
1972 Custom/10 SWB, 4.8/4l80e
Build thread
LSx Swap FAQ index
usmcchevy is offline   Reply With Quote
Old 12-17-2011, 11:12 AM   #3
Shortie
Junior Member
Shortie's Avatar
So far im still trying to figure out where to get key on from. Ive checked both of my ignition switches with a multimeter, and all but the starter feed goes dead during crank
Old 12-17-2011, 12:51 PM   #4
usmcchevy
usmcchevy's Avatar
The ignition switch in mine is from a '72, maybe there is a difference.
Build thread
LSx Swap FAQ index
Old 12-17-2011, 01:08 PM   #5
ls1nova71
ls1nova71's Avatar
I would use the wire that originally powered your distributer/coil, that will have power while cranking.
ls1nova71 is offline   Reply With Quote
Old 12-17-2011, 10:59 PM   #6
HavinSomeFun
Still Just Havin Some Fun!
HavinSomeFun's Avatar
Thats what I used.. Works perfect!
a green one with some stuff done to it....
HavinSomeFun is offline   Reply With Quote
