Old 12-23-2011, 12:10 AM   #1
SunSoaked
SunSoaked's Avatar
New Member with 69 C10 4x4-Axle Swap?
Just bought a "fixer-upper" 69 4x4 C10. First thing on my list is to lose the front drum brakes. This is a daily driver. Intentions are a restoration and average off road use. No rock crawling, towing huge toy haulers, etc.
I have access to a 85-87 era blazer (military version). It has disc brakes and "maybe" lower gears (4:10/4:56?) and a posi. Given my intended use, I think the corp 10 bolt would be plenty strong.
Question: Would swapping both axles be a straight forward deal? I would gain much newer axles, open knuckles and disc brakes for no cost.
I will be installing an injected 383 and a 700r4 if that matters.
Thanks for the info. I'm glad to quit lurking and finally join the site.
Mike
SunSoaked is offline   Reply With Quote
Old 12-23-2011, 08:15 AM   #2
Chevy1TonFun
Grease Monkey
Chevy1TonFun's Avatar
Re: New Member with 69 C10 4x4-Axle Swap?
I think that would be a perfect axle to swap for you. A 10 bolt would have disc brakes for sure. There might be a few items you have to change out, i.e. brake lines and maybe steering linkage. 99% would be a direct swap. You have to re-gear your rear axle if the gear ratio is different from the front. I would also suggest a LS swap instead of the 383 stroker. Good Luck!
Tow Rig: 2012 Chevy 2500HD CCSB LTZ Z71 4x4 Duramax
Ultimate Offroad Build: 1978 Chevy Silverado K30 Crewcab Build Link http://67-72chevytrucks.com/vboard/s...d.php?t=654053
Mud Truck: 1972 Chevy Cheyenne K30 4x4, 468/400/205, D60/D70HD, 18" Custom Lift, 17x39" IROKs
FOR SALE http://67-72chevytrucks.com/vboard/c...ton-4x4&cat=12
Chevy1TonFun is offline   Reply With Quote
