12-28-2011, 01:10 PM | #1 |
Bench Bleeder Tool
Anyone ever use a Cardone bench bleeder tool? I hope you can see the pic.
12-29-2011, 01:04 AM | #2 |
God is good!
Re: Bench Bleeder Tool
No, but you don't really need it. If you are buying a new MC, it should come with some screw-in plugs for the ports. Fill the MC with fluid, and push the part where the push rod goes. You will see bubbles when you do this. Keep pushing until the bubbles stop. Check out Youtube for some how-tos.
Mando "It takes a smart man to know when he's stupid." -- Barney Rubble My build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=430367 |
12-29-2011, 02:56 AM | #3 |
Moderator
Looks like it might be useful if it really cuts down bench bleed time. The parts aren't cheaper than just buying one.
12-29-2011, 09:05 AM | #4 |
I saw the video of the bleeder tool. It only cost about $12.00. I think I will buy one. If I never use it again I will give it to my son. He is air bagging a 69. I think it might be a faster, and better way to bleed the brakes.
12-29-2011, 09:22 AM | #5 | |
Don't get me wrong, that's a darn good idea (wish I thought of that) but $12 for the tool seems outrageous especially when the feed store has bigger ones for only a couple dollars.
My Projects: 1960 GMC 1/2ton with 305 V6 (daily driver) 1963 Chevy 1/2ton 2wd...converting to 4x4 1967 Suburban 1/2ton 2wd My Girlfriends Projects 1985 Chevy Suburban 3/4ton 4x4 with 6.2L diesel, 4" lift, converted to TH-400, Warn Premium manual hubs, & Wildcat 315/75/R16 tires. (daily driver) 1978 Camaro Type LT with a Marine 350 & vortec heads, Rochester Carb, & roller cam 1978 Camaro Z28 |
12-29-2011, 12:00 PM | #6 | |
Moderator
I have a homemade ACE 2gal garden sprayer pressure bleeder for actually bleeding brakes. It cost me $30 in parts 7 years ago. I just screw on the MC cap, pump it up to 18psi, and open the valve. Liter pop bottles make great catch cans. |
12-30-2011, 07:24 PM | #7 |
I used it and it works great. Very simple to use.
Too many dreams, too little money. |
01-08-2012, 05:10 AM | #8 |
Not sure what the fuss is about. Making a jig to bench bleed a master cylinder is a piece of cake. Also, speed bleeders, the ones that fit on the wheel cylinders, work very well.
1969 c-10 Step Side Long Bed. I-6 250cid = = 1969 Pontiac GTO hard top. 400, 4-speed. |
01-08-2012, 12:00 PM | #9 |
I agree I use speed bleeders, then a vacum pump. takes me about an hour or so to bleed all 4 corners after installing a new MC. I usually do it myself, a second hand might be quicker
Memo S. Retired US Marine Family Man |
01-11-2012, 10:20 PM | #10 |
Used one in the 80's. I found it to be messy, quick enough, but messy. I despise the feel of Dot 3 on my hands. Dot 3 and antifreeze, both just feel weird on my hands.
I just use plugs any more and let the bubbles fly.
'70 GMC C1500 LWB Power disc brakes. WooHoo! Posi 6 Lug Dana 60 |
01-12-2012, 12:53 AM | #11 |
01-13-2012, 09:00 AM | #12 |
I could not get my brakes bleed. I took the truck to a shop, and had them power bleed.
