Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 12-28-2011, 06:49 PM   #1
bigboybodry
bigboybodry's Avatar
28 10.5 tires
The new race season starts off with new rules and I can no longer run the 31 10.5w tires. we can only run a 28 10.5 no w's this year so anyone running the tire I could use alot of help. The last time I tried to run the 28 10.5 it blew the tires off.
first track pass with the new motor on motor http://youtu.be/YgrJaEF_TaQ
bigboybodry is offline   Reply With Quote
Old 01-16-2012, 09:30 PM   #2
djracer
djracer's Avatar
Re: 28 10.5 tires
Is that the only tire or is their a radial option?
Kevin
Special Thanks to All who have helped on the TRUCK!
My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4
So Far my best Times are:
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
5.785 1/8 @ 118.65 with a 1.336 60ft
9.168 1/4 @ 142.58 with a 250 shot dead out of the hole!
djracer is offline   Reply With Quote
Old 01-23-2012, 11:36 PM   #3
bigboybodry
Re: 28 10.5 tires
Sorry it took so long I broke my wrist and had to have surgery and all.
28 10.5 no w's or a 275 60 15 what you guys think?
Old 01-24-2012, 10:53 AM   #4
GMR-PERFORMANCE
GMR-PERFORMANCE's Avatar
Re: 28 10.5 tires
I messed around with tires in the 10.5 size and found that it becomes a buy and test game. I had to run the softest compound I could fine. I ended up running firestone's , I do not recall what compound it was though. But they did hook. I ended up running less gear as well. it makes you change a bunch of things in your set up. But once I got it dialed back in the little truck was back to hanking the front wheels off the ground again.
The up side was almost no tire shake though.. for what thats worth
GMR-PERFORMANCE is offline   Reply With Quote
Old 01-24-2012, 12:29 PM   #5
kpeztruck
kpeztruck's Avatar
Re: 28 10.5 tires
The Mickey Thompson, and Hoosiers both work well. THe Hoosiers will shake your teeth out of your head, if you do not tune your chassis to them, as they have an aggressive compound. I am going to try some M&H 28x10.5 tires, and see how they perform. Some racers in North Georgia and Tennessee have had some good success with them, and Coker tires is a dealer for M&H. Coker owns Phoenix tires, but I do not think they market a 28x10.5 at this time. THe Phoenix brand is for the most part from the Firestone molds, and have an aggressive compound. If you are interested in Phoenix or M&H, call Eric Gullet at Coker tires, his number is (426)265-6368, tell him Paul Baxter sent you his way. Thanks, Paul
kpeztruck is offline   Reply With Quote
Old 01-24-2012, 02:03 PM   #6
bigboybodry
Re: 28 10.5 tires
thank guys I going to need all the help I can get going from a 31x10.5w to a 28x10.5. I was thinking along the lines of a 3.50 gear to start?
Old 01-24-2012, 02:23 PM   #7
kpeztruck
kpeztruck's Avatar
Re: 28 10.5 tires
What kind of class you running? Heads up, index, bracket? If heads up, I would not switch to such a tall gear. I plan to run the same tire on my truck, with a 540 BBC on one fogger with a large tune up. I have the MSD 7531 to help manage power, as well as some chassis and engine tricks. The converter will also have to be correct for the combo, but you can fly on a 28x10.5 tire, and still run the proper gear to pull hard through the finish line. Paul
Old 01-24-2012, 02:44 PM   #8
bigboybodry
Re: 28 10.5 tires
heads up. my combo ended up being a 512 with a pro shot fogger on bottom and sportsman up top, th400 with brake custom, bte custom nos converter and still running a 12 bolt 35 spline axles full spool and 390 gear.
Old 01-24-2012, 03:18 PM   #9
kpeztruck
kpeztruck's Avatar
Re: 28 10.5 tires
What ignition box part # are you running? This sounds like a very good combo the way it is, if you have a way to manage power. You already can to an extent, since you have 2 systems, put one on a timer, if the class rules allow. The class I plan to run only allows one system, no progressors, and no timers. Has to be all on at the release of the trans-brake!! Sounds fun just talking about it. Paul
Old 01-24-2012, 08:05 PM   #10
hotrod 80
mini truck racer
hotrod 80's Avatar
Re: 28 10.5 tires
The 2.48 over the 3.90 is alot of mechanical advantage . Did they specify 28" or just say true 10.5 ? If just a true run a 29.5 . I would test with the 3.90 , but your on the right track . I came up with 3.40 with a 28 " tire and 400 . I had a 3.60 in the garage , so i'll probably be heading that direction .
X2 on the ignition box and pulling timing .
1949 5-window
1969 Camaro
1976 Chevy Luv yellow
1978 Chevy Luv Blue
1976 Chevy Luv Black
1979 Firebird Flooded in Harvey
1999 F350 Dually
2005 GMC Sierra 4.8 RCSB
2014 Explorer (wifes)
My build :http://67-72chevytrucks.com/vboard/s...d.php?t=399148
Build #2: http://67-72chevytrucks.com/vboard/s...d.php?t=653583
hotrod 80 is offline   Reply With Quote
Old 01-24-2012, 08:55 PM   #11
bigboybodry
Re: 28 10.5 tires
I have a msd 7al3 in the truck. The pro fogger is on a nos progressor and the small is on the button.
Old 01-24-2012, 08:59 PM   #12
bigboybodry
Re: 28 10.5 tires
they said max 28x10.5 no w's
Old 01-25-2012, 07:07 PM   #13
kpeztruck
kpeztruck's Avatar
Re: 28 10.5 tires
Put both on progressors, or, leave on the small kit, and test to figure out what the combo wants with start time/percentage, and pill size for the second system. There is still a lot you can do with the 7al3, just have to be a little more creative. Are you running 1/4 or 1/8, and what kind of trap rpm would your engine combo be happiest with? I would have the rear gear to go the quickest and fastest, then make chassis/and engine tune changes as needed. The 28x10.5 tire is very good, and I have seen high 4.80's in the 1/8 from this tire. Paul
Old 01-25-2012, 10:09 PM   #14
bigboybodry
Re: 28 10.5 tires
I will be running the 1/4, I haven't run it at the track yet with the new setup. I guess its going to be trial and error and just see what it likes. the cam shaft was giving me problems and was to big so I am trying to find all the new specs out before I order the new one. I hate to order a cam without knowing what the truck needs.
