Old 01-02-2012, 04:35 PM   #1
davepl
davepl's Avatar
My 402 heads are listed for "366/427"
The casting numbers on the cylinder heads for my 70 GMC 402 are 3975950, which at every source I've checked shows them as
1968-70 366/427 2.06/1.72 Closed Chamber
The block is TO42TTBG, which is 402. Now I'm a little confused, because the 366/427 are tall-deck engines and the intake manifold wouldn't fit, even if you could mix and match tall deck heads with a short deck block.
Are the sites I've checked all wrong, or do I have the wrong heads on this truck?
Thanks!
Dave
1970 GMC Sierra Grande Custom Camper - Built, not Bought
1969 Pontiac 2+2 427/390 4-speed Coupe
1969 Pontiac 2+2 427/390 4-speed Convertible
davepl is offline   Reply With Quote
Old 01-02-2012, 06:56 PM   #2
425HP409
425hp409
425HP409's Avatar
Re: My 402 heads are listed for "366/427"
The heads will interchange between tall and short block. The .400" taller block puts the heads wider apart and that is why you must have a 366/427 tall block intake.
Charles
68 SWB, Dad bought new, now 396 & factory ac
64 Impala SS, 409 425HP, 4 speed AC
64 Bel Air Wagon, 400 Small Block
57 Bel Air all original 283 w/Factory Air
77 GMC Sprint, 454/425HP
67 Olds 442, all original
90 ZR1 Corvette
425HP409 is offline   Reply With Quote
Old 01-02-2012, 06:59 PM   #3
davepl
davepl's Avatar
Thanks! And from searching, it appears these heads are not uncommon on the 396/402, just bad reference material I was looking at I guess.
Old 01-03-2012, 08:21 AM   #4
They could have been replaced.
