01-02-2012, 06:01 PM | #1 |
Rear Wheel Bearings 68 C20 2WD
Hi,
I have completed rebuilding the drum brakes in my C20 1968 pickup and now want to remove and replace both rear wheel Bearings. Simple question, how do you remove them?? I can't figure it out... Thanks ahead for your help! Chris |
01-02-2012, 06:17 PM | #2 |
Re: Rear Wheel Bearings 68 C20 2WD
On my C10 I used a slide hammer with a 2 hook attachment, but my bearings weren't in the drum either.
65 SWB BBW - 283, TH400 |
01-02-2012, 08:00 PM | #3 |
If that's an eaton setup, which I am sure it is, just yank out that seal, that bearing should just slide out then the outer bearing is held in with a big clip that you'll need some needle nose pliers and gumption to get out.
Posted via Mobile Device |
01-02-2012, 09:15 PM | #4 |
ok... As you can see in the top right picture, there is a rubber seal.... I did not want to yank that off until i know that is the right thing to do.
Also, am I right to say that these bearings do not need to be packed/greased and the diff lubricant will work as the lubricant? Chris B |
01-02-2012, 09:31 PM | #5 | |
20' Daredevil (Ret)
Check this thread: http://67-72chevytrucks.com/vboard/s...d.php?t=475710
01-02-2012, 09:50 PM | #6 |
This isn't really an answer to your question, just offering a suggestion. I have the same hub/drum arrangement on mine. I was totally unfamiliar with it so I got a Service Manual. I haven't replaced the bearings, but the Manual (and several archived posts in here) got me through removal, dissassembly, and reassembly of the hub/drum assembly. I'd copy the procedure but it's spread across four pages and I can't get decent pics with my camera. I think you'd find the Manual helpful for this and future tasks on your truck.
- Jim - My Daily Driver is a 1969 Chevrolet Custom/20 Fleetside 350/TH400/Eaton H052 4.10 and its Project thread is here http://67-72chevytrucks.com/vboard/s...d.php?t=456911 |
01-03-2012, 03:28 AM | #7 |
[never mind. mis read the post]
1969 c-10 Step Side Long Bed. I-6 250cid = = 1969 Pontiac GTO hard top. 400, 4-speed. Last edited by GRX; 01-03-2012 at 03:39 AM. |
