Old 01-02-2012, 06:51 PM   #1
67 Burb
67 Burb's Avatar
Wheel Swap
My 67 Suburban 2WD has 6 bolt wheels, of course and I'm wanting to install winter tires on a spare set of rims. I'm wondering if newer Chev wheels (from the 90's) will fit OK without problems. Are the original wheel studs long enough to mount aluminum wheels? Or do I stay with steel wheels. How about the hub hole? Are they a fit?
Bob
67 Burb is offline   Reply With Quote
Old 01-02-2012, 07:08 PM   #2
john
member #16
john's Avatar
Re: Wheel Swap
The center holes are smaller on the newer wheels.
john is offline   Reply With Quote
Old 01-02-2012, 11:39 PM   #3
67 Burb
67 Burb's Avatar
Re: Wheel Swap
Thanks, John. I was afraid of that.
Bob
Old 01-02-2012, 11:42 PM   #4
grancuda
grancuda's Avatar
Re: Wheel Swap
I have some 6x5.5" to 5x4.5" billet adaptors that make it easy to find wheels. Around here it seems like you can get stock jeep wheels cheap.
grancuda is offline   Reply With Quote
Old 01-03-2012, 12:54 AM   #5
YBNORML
YBNORML's Avatar
Re: Wheel Swap
Bob
Any machine shop can machine the centers to required diameter. I had this done to the 24's I run on my shortbox. It cost me $110 for the pair.
Jason.
68’ GMC shortbox
72' 2WD Blazer
67' LongBox C-10
InstaGram ybnorml67
Old 01-03-2012, 09:45 AM   #6
AzDon
AzDon's Avatar
Re: Wheel Swap
I tried to put some of the 90's flat hubcap aluminum wheels on my 67 burb and the tires hit the inside well long before I could check the fit at the boltface!
In the 80's, GM started using enlarged tapers at the lugnut seats and different metric stud sizes. In the 90's they moved the axle ends outward and used wheels with more backspacing.
AzDon is offline   Reply With Quote
Old 01-03-2012, 12:21 PM   #7
67 Burb
67 Burb's Avatar
Re: Wheel Swap
Thanks, everyone. I was hoping it wouldn't be this difficult.
Bob
Old 01-03-2012, 11:40 PM   #8
Already Gone
70+ ( Old Skool Club )
Already Gone's Avatar
Re: Wheel Swap
Hi Bob.. I am thinking if you got some 6 hole stock steel rims from a 73/87
3/4 ton I think they should work and as you probably know there are tons of those trucks in wrecking yards. If they won't work I'm sure someone will mention it on here.
1992 K1500 GMC Suburban
" Circumsatances Do Not Change Responsibility "
" The Sky is not the Limit, Your Mind is." Marilyn Monroe ..
RIP Charlie Watts 1941 - 2021
Old 01-04-2012, 02:01 AM   #9
67 Burb
67 Burb's Avatar
Re: Wheel Swap
Hey, Greg. I'll keep looking. There's gotta be something around.
Hope the weather's looking good up there in Toon Town. We're heading up on the 9th or so for a couple of weeks.
Bob
Old 01-05-2012, 04:41 PM   #10
Already Gone
Re: Wheel Swap
Theses are the wheesl I emailed you about Bob. The weather has been unseasonally warm with it being + 16 in Maple Creek Sask. yesterday. The ones on my truck are 5 hole but I have 6 hole wheels.
wheels
