Old 04-24-2003, 06:56 PM   #1
rin68
rin68's Avatar
ECE vs. CPP
I'm doing the whole suspension rebuild/drop thing in the next month and am just about ready to start ordering parts. Anyone have good/bad dealings with these two companies? They both seem to make some high quality parts and are very knowledgeable, but currently I'm leaning towards the CPP Grand Slam Kit and a couple more accessories from them.
The plan is a 2.5/4 drop(spindles in front) with disc in front and the master cylinder/booster set up for 4-wheel discs
1968 C10 - 383, non-stop project
1969 Camaro - 327, bone stock family heirloom...soon to be LS/T56, Ridetech, all the goodies
rin68 is offline   Reply With Quote
Old 04-24-2003, 07:01 PM   #2
72MARIO
72MARIO's Avatar
I think CCP use Western Chassis Spindles What kit are you getting ? Is it the one that allows you to use 73 up brakes ? If so I have some tips for you. Let me know. Either Company has good parts.
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair
http://67-72chevytrucks.com/vboard/s...d.php?t=625017
1967 C/20 6.0/4L80 Roofing Truck
1990 V2500 Suburban "Plow Truck"
2005 TAHOE DD
72MARIO is offline   Reply With Quote
Old 04-24-2003, 07:03 PM   #3
rin68
rin68's Avatar
the kit i was looking used 73-up ball joints, brakes, etc (that's how i understood the guy on the phone) have you used that kit mario?
Old 04-24-2003, 07:10 PM   #4
Alexis
Member since 2000
Alexis's Avatar
ECE all the way. Even though CCP is a good company and i got nothing bad to say about them. I personally trust ECE alot more and they build there product to fit your truck. Not making you build around there products.
Alexis is offline   Reply With Quote
Old 04-24-2003, 07:14 PM   #5
72MARIO
72MARIO's Avatar
Yepper .
Here is the trick. Hope you have the center link with the small holes in it if not you will have to find one. I had a hard time trying to figure out why my tie rods went right thur the holes. I learned that there were two diffirent styles that came on our trucks One had huge holes that the tie rods bolted in the other style(the one you need) has small holes. Now you use 67-70 outer tie rods on the inner. (not a error) You may need to cut a bit off them to allow eough adjustment so that you can get enogh toe in. Use 73 up flex hoses I will post a pic showing them on my frame. I think thats all.
2005 TAHOE DD
Old 04-24-2003, 07:15 PM   #6
72MARIO
72MARIO's Avatar
The hole you need is already in the frame.
2005 TAHOE DD
Old 04-24-2003, 07:17 PM   #7
rin68
rin68's Avatar
mario
thanks for the info, i have a couple center links laying around. pretty sure that i have at least one of each style....is that pic of the hoses that come with the kit?
Old 04-24-2003, 07:21 PM   #8
72MARIO
72MARIO's Avatar
I had to buy these hoses they were cheep. 20 bucks CDN. I like the kit once I figured out how everything went together. I also choose this kit because you can get more redeally avaible brake parts for your truck and they are also a bit cheeper. Hope this helps.
Let me know if you have any more Questions
Later
2005 TAHOE DD
Old 04-24-2003, 07:21 PM   #9
gr8scott51
gr8scott51's Avatar
I bought a 3"/5" kit from Early Classics - springs, shocks, rear shock relocation mounts and panhard bar. I know it's not the same, but I got it done in a day.
When I decided to rebuild my front end, I bought the kit from CPP. It took a little longer and I had to order lower A frames cuz mine were split, but the kit was excellent.
So, I guess what I'm saying is, you can't go wrong with either of these companies.
Good luck, let us hear how it goes. Scott
Silence is golden, duct tape is silver. - Scott
gr8scott51 is offline   Reply With Quote
