Old 01-05-2012, 08:46 PM   #1
woodwright
Enjoying left field
woodwright's Avatar
Alternative Heater
Any body modified the heater assembly from another vehicle to work in our trucks? I don't have room for the outer firewall assembly, but I don't want to buy an aftermarket unit. I don't have the money, and it just seems like thats cheating
I thought about using the rear heat unit from my 93 suburban, but it's bigger than I thought. I like the control panel though. I don't need AC, just a heater with defrost and floor heat.
Clint
70 Chevy 4WD "Ultimate Work Truck" SOLD
woodwright is offline   Reply With Quote
Old 01-05-2012, 10:34 PM   #2
Scott Webster
Sheetmetal Psycho
Scott Webster's Avatar
Re: Alternative Heater
My interior is shot and stripped. When my heater core sprung a leak I refused to pay lots when I fugured that the fan didn't work either. I ended up using a transmission cooler with a 12 volt fan blowing behind it. Doesn't defrost well, but I have a hf fan for that. I know it isn't what your looking for, but it worked in a pinch.
I didn't say you were stupid, but I was thinking it... I need a check up from the neck up!
Project "Rigginstine's Monster"
1971 C-10 longbed 355/4spd
Future mods: 67 front clip
Webby's Rigginations - where everything has potential!
Scott Webster is offline   Reply With Quote
Old 01-06-2012, 12:32 AM   #3
ETsC10
Hand Crafted C-10
ETsC10's Avatar
I don't know about retro-fitting from another vehicle, but I might shed light on aftermarket.
You may want to start haunting ebay for older add-on units for campers, etc.
I had a neat, self-contained unit (didn't need anything but a supply to and from the radiator),
earlier this summer, that was designed for a camper. Oldie but goodie. I sold it, but there
may be more out there.
I have no idea what brand it was.
Other than that, I had a Mohave heater & plenum that I also sold. I would think they probably
run under $300 and will give you everything you need, other than controls, and still fit under the dash.
Good luck on your quest...subscribed.
ETsC10 is offline   Reply With Quote
Old 01-06-2012, 01:02 AM   #4
woodwright
Enjoying left field
woodwright's Avatar
The controls on the aftermarket units that I have seen are basically on or off. I would like fan, temp, and location controls like a factory system. I would also like to get away from the sliding cable controls.
Clint
