Old 01-08-2012, 06:19 PM   #1
prostreetC-10
My Carbon Footprint
prostreetC-10's Avatar
What? oh okay.....this is why you run a big block!
Guys.....just had to share. Now that my "shakes" are gone I thought I would post up a fun video. This is a testament about not going too big and parts matching. It's a BONE STOCK 454 with stock, small valved 781 heads. It has almost NO compression (don't even think it's 8:1) and a really small roller cam. Yes, that's a tiny 650 double pumper!!
For those of you that have ever video'd, in the rig was much more scary than the video shows. She flat scoots!
Turn up your volume.
http://youtu.be/uUtAvw0tEws
http://youtu.be/IdS8o4dmZtM
http://youtu.be/Q56GHXjgGgM
prostreetC-10 is offline   Reply With Quote
Old 01-08-2012, 06:34 PM   #2
BMERDOC
BMERDOC's Avatar
Re: What? oh okay.....this is why you run a big block!
Good times! Good times! My Honey WILL be rockin a BBC one day. I knew it didn't have to be hot to be fun and you just proved it to me!
Nick Carter
1967 C10 Short bed Fleetside
Project Cheap Thrills!
2WD C10 Modern/Performance Alignments
Easiest Alignment Ever!
BMERDOC is offline   Reply With Quote
Old 01-08-2012, 07:01 PM   #3
snj8198
snj8198's Avatar
Man if that don't get a raise out of a guy I don't know what would.
Great, now I just blew 30 minutes on youtube hotrod vids. Thanks prostreet
Steve
1971 GMC Longbox. Full Roller Stroker 489 w/ FiTech EFI, Chris Straub Cam/NV4500/205/D60/14B w. Grizzly Locker and 4.11's. 2" Lift on 33's
snj8198 is offline   Reply With Quote
Old 01-08-2012, 07:27 PM   #4
sbc10guy
sbc10guy's Avatar
That looks like a lot of fun, seems to have tons of power for being pretty much stock. I hope my 402 turns out half that good.
1969 shortbed c/10
1998 GMC sierra
sbc10guy is offline   Reply With Quote
Old 01-08-2012, 07:54 PM   #5
crazy longhorn
Fabricate till you "puke"
Awsome! But methinks you should put an air filter on that rat....before she sucks "big bird" out of the sky crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 01-08-2012, 08:19 PM   #6
prostreetC-10
My Carbon Footprint
Yeah I do need to get an air cleaner. I was testing a customer's carb. I sent him the videos and he sent back a big smile.
SBC10guy:
Just realize that I have you by 52 cubic inches and the 781s are excellent "stock" iron heads. If your heads are "truck" heads then they won't flow quite like these. Oh yeah....I also have about $800 JUST in my valve train. With that said, I have a truck 396 in my 3/4 ton farm rig. I'm very happy with what it can do. The torque alone that you will pic up over a mild sbc will be gobs.
Old 01-08-2012, 10:50 PM   #7
sbc10guy
sbc10guy's Avatar
Ok i didnt realize you had good heads with work done to them. My motor is the passenger car motor and the heads are 292 so they are decent oval ports and they are shaved .030 for a little more compression. I think it should do decent but probably not as well as that 454. Plus it will be in the heavy chevelle compared to a truck that is lighter in the rear.
1969 shortbed c/10
1998 GMC sierra
Old 01-08-2012, 10:59 PM   #8
prostreetC-10
My Carbon Footprint
No work done. They are bone stock. I just installed the correct springs and roller rockers. Valves, ports....etc are stock. No milling. More hope?? She'll run just fine.
Old 01-08-2012, 11:06 PM   #9
sbc10guy
sbc10guy's Avatar
Ok, im having a decent amount of work done to mine and i guess really id doesn't take much to get 800 into a set of heads now that i think about it. Im not looking forward to my bill when the shop calls and tells me mine are done. I am also hoping to get some aluminum roller rockers eventually. So yah a little more hope.
1969 shortbed c/10
1998 GMC sierra
Old 01-08-2012, 11:24 PM   #10
YBNORML
YBNORML's Avatar
HaHa, looks like fun. Someday Hopefully my bigblock will run again
Jason.
68’ GMC shortbox
72' 2WD Blazer
67' LongBox C-10
InstaGram ybnorml67
Old 01-09-2012, 12:04 AM   #11
dukcaln
dukcaln's Avatar
come on, let us see that thing WOT through the gears MAN!
04 CHEVY LLY LS DURAMAX 4WD. MODS TO FOLLOW, EFI LIVE, BUILT TRANS, LBZ MP, LIFT PUMP
SOLD 1972 chevy c10
dukcaln is offline   Reply With Quote
Old 01-09-2012, 12:25 AM   #12
greywuuf
and a pic of what its in !
greywuuf is offline   Reply With Quote
Old 01-09-2012, 12:44 AM   #13
prostreetC-10
My Carbon Footprint
Problem is it's somewhat of a rough country road. It's the kind that the gravel shoulder is about 2 inches past the white line. Not much room for error. This thing has only been on the road about 5 times since I built it. I have some suspension geometery I need to get ironed out before I make full passes. If you go back and look at the first video, it was just starting to get away from me when I backed out. If you look at the last one, You'll see me get back on it in 3rd but it just blows the tires up again!
This is what it looked like when I started in. A 74 is certainly not my idea of a cool Camaro but I was looking for ANYTHING before I found this (El Camino, Monte....etc). I couldn't turn down $500 for a solid roller. It turned out to be in great shape for the money.
Old 01-09-2012, 01:07 AM   #14
YBNORML
YBNORML's Avatar
I never used to be a fan of this gen camaro, but they have really started to grow on me. OH, and a well built big block definately helps
Jason.
68’ GMC shortbox
72' 2WD Blazer
67' LongBox C-10
InstaGram ybnorml67
Old 01-09-2012, 11:13 AM   #15
into69z
"brand new second-hand"
into69z's Avatar
WOW-looks like great performance from that big block! I have a 74 454 bored 60 over with 781 truck heads. Everything was rebuilt and balanced to the 74 specs.( about 8:1 comp ratio). I put in a comp cams XE262H-10 with the matching springs and 7/16 push rods and roller tip rockers, edelbrock rpm manifold with a new edelbrock 750 electric choke carb, headers and an HEI ignition( China made). It is coupled to a fresh turbo 400 with a 3:23 rear end.
My truck does not perform anywhere close to your ride. Does a roller camshaft make that much difference in over all power? I should be able to spank the tire too( open rear) but nothing like what you have. Any ideas on something in my set-up I might have missed? Sorry to high jack your thread but your truck gets it on!
Steve
69 3/4t custom camper
tilt,am/fm,speed warning,air gauge,buddy buckets,aux battery, big block,p/s,p/b,a/c
67 Camaro
96 Impala ss-sold
04 hybrid Honda-saving gas for the blue truck!:
b69:
into69z is offline   Reply With Quote
Old 01-09-2012, 01:25 PM   #16
prostreetC-10
My Carbon Footprint
A few things: First of all, a roller cam CAN make a huge difference. This motor used to have a crane 272H single pattern with .515 lift. There is a noticeable difference with the roller. The R's just shoot up. Now in all fairness to you though, I have a 3K stall, 4.20 gears and at least 1,000 lbs on you. That stall alone is like a sling shot. I wouldn't get too hung up on comparing a big heavy truck to this rig.
A big factor can be your timing. These low comp BBCs love a lot of initial timing. That motor is set at 18*. What are you set at? I do know that when this was in my 5,600 lbs 3/4 ton, it flat ripped for a truck too though.
Old 01-09-2012, 01:41 PM   #17
dukcaln
dukcaln's Avatar
man these big block videos remind me of when I was young riding in the old mans HEMI CUDA! I need to look for a big block later down the road...
SOLD 1972 chevy c10
Old 01-09-2012, 01:52 PM   #18
shawno72
C/10 junkie
shawno72's Avatar
Now THAT looks like fun!!!!!!!!!!
Shawn
70 LWB C10 current driver/project
http://67-72chevytrucks.com/vboard/s...d.php?t=663051
68 SWB C10 Work in progress.....SOLD
http://67-72chevytrucks.com/vboard/s...d.php?t=559520
72 LWB C10 Sold
71 LWB C10 Sold
68 LWB C10 CST Sold
http://youtu.be/kbB0QrBIs9k
My mom always had the best advice. It was just a tad late. After a fall that involved blood, she'd say....."Careful!"
shawno72 is offline   Reply With Quote
