01-09-2012, 09:21 AM | #1 |
Brake system bleeding - Speed bleeders. Best thing since sliced bread.
Anyone else here use them? With a little prep work of the master cylinder on the bench, speed bleeders make this once painstaking job a breeze. When refurbishing (new master cylinder, wheel cylinders, hoses and lines) the brake system on the truck in my sig, I was able to bleed the entire system by myself in less than half an hour. Replaced a master cylinder on a friend's '71 Barracuda recently, and with someone working the pedal while I kept the master cylinder filled, it went even faster.
For those who aren't familiar, speed bleeders take place of the stock units and essentially become a one way check valve preventing air returning into the system. Tighten the bleeder, back out 1/4 to 1/2 turn and go. No need to have an assistant hold the pedal down while you tighten the bleeder. Simply pump the pedal up and down. Then tighten the bleeder when done. As always, comments & suggestions appreciated. Russell Speed bleeder web page: http://russellperformance.com/mc/speed/domestic.shtml $8.46 a pair at Summit: http://www.summitracing.com/search/P...r&autoview=SKU
1969 c-10 Step Side Long Bed. I-6 250cid = = 1969 Pontiac GTO hard top. 400, 4-speed. |
01-09-2012, 09:38 AM | #2 |
Re: Brake system bleeding - Speed bleeders. Best thing since sliced bread.
there really is no need to have someone hold a pedal down while you tighten a bleeder// just need a cement block
01-09-2012, 09:38 AM | #3 |
C/10 junkie
At work we use a pressure bleeder. Basically it's a contraption that holds a large amount of brake fluid and you hook it to the top of the master cylinder. Plug in a hose from your air compressor and walk around to each bleeder valve and open, no foot needed. The next best thing is what you have here, makes it very easy to do at home by your self.
Shawn 70 LWB C10 current driver/project http://67-72chevytrucks.com/vboard/s...d.php?t=663051 68 SWB C10 Work in progress.....SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=559520 72 LWB C10 Sold 71 LWB C10 Sold 68 LWB C10 CST Sold http://youtu.be/kbB0QrBIs9k My mom always had the best advice. It was just a tad late. After a fall that involved blood, she'd say....."Careful!" |
01-09-2012, 11:32 AM | #4 | ||
