Old 01-09-2012, 09:31 AM   #1
Asahi123
Coolant level low when cold?
Why is the coolant level low about 3 or 4 inches when it is cold? But when it get to operational temps it is to top of the radiator? Info 71 Chevy 350 engine automatic trans. I have flush the coolant. It doesn't overheat just bothersome.
Asahi123 is offline   Reply With Quote
Old 01-09-2012, 09:33 AM   #2
cdowns
cdowns's Avatar
Re: Coolant level low when cold?
heat expands// learned that in general science
Old 01-09-2012, 09:49 AM   #3
yuccales
yuccales's Avatar
Don't worry, that's normal. As your coolant heats up it expands, and needs somewhere to go. If you are worried about it, you could get a coolant recovery bottle & a closed system radiator cap. This would insure your radiator was full to the top all the time, and keep coolant from pouring out your over flow tube.
yuccales is offline   Reply With Quote
Old 01-09-2012, 10:08 AM   #4
Asahi123
Thanks for your replays.
Old 01-09-2012, 12:07 PM   #5
Lee H
Lee H's Avatar
3-4 inches below the neck is normal cold fill level. If you fill it up higher than that it will drain out the overflow tube when hot and return to the cold fill level after a few heat cycles.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner.
1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components.
My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703
Lee H is offline   Reply With Quote
