Old 04-25-2003, 01:23 PM   #1
BUXMAN66
go bucks!
anyone use poly bushings on rear sway bar?
and if so did you notice much difference?this is a stock sway bar........for a 68 1/2 t. also, are these bushings a press fit? thanks to any and all replies......
'68 swb 1/2t 350/350th
'86 lngbd 3/4 TON parts getter
'49 gmc 1/2 t 5 window 350/350th
'96 gmc sonoma sle ext-cab. hey it's a 4cyl. 5 spd and good on gas y'know?
BUXMAN66 is offline   Reply With Quote
Old 04-25-2003, 05:42 PM   #2
Tuck
I bought a set , then ordered a new adjustable arm. so I have a set if you need them. I am only a state away so shipping will be cheep.
Tuck is offline   Reply With Quote
Old 04-25-2003, 06:08 PM   #3
casey
casey's Avatar
I'd just like to find a rear sway bar need one for my 71chev 4x4
casey is offline   Reply With Quote
Old 04-25-2003, 06:17 PM   #4
cdowns
cdowns's Avatar
are you talking about the panhard bar or sway bar???????????
Old 04-26-2003, 01:37 AM   #5
casey
casey's Avatar
whats a panhard bar apposed to a sway bar
Old 04-26-2003, 02:23 AM   #6
BUXMAN66
go bucks!
yeah what he said! panhard bar is adj. and a stock sway bar ain't.....right? if somebody can confirm that my stock sway bar is the same for the size bushing's you got i'll take 'em,tuck......
Old 04-26-2003, 02:39 AM   #7
Low69CST
a panhard bar is a 3rd link, like a trailing arm, expect the other direction, it actually serves to physically locate the rear end under the truck and adds no tennsion to anything, adjustable or not. A swaybar is a spring that helps transfer weight during cornering. It acts like and 3rd spring besides your 2 coil springs. It does in no way serve as a link to physically hold your rear end in place.
'69 CST Short fleetside
Lowered, 400 small block, 700R4, 4 wheel disc brakes, front sway bar & rear camaro sway bar (in progress)
'87 V10 4x4 Short Fleetside
Quad Suspension and Dual Tanks
Low69CST is offline   Reply With Quote
Old 04-26-2003, 04:05 PM   #8
slam33
slam33's Avatar
The panhard bar runs from the rear driver side single post mount to the pass side of the rear end. I use the polys on it becuse they last longer and there a snap to install.
71 LWB 350/350still working on it but it's going tp be sweet. www.geocities.com/stevemau/slam33page.html
" TARGET=_blank>http://www.geocities.com/stevemau/slam33page.html?1004806705410
</A>
slam33 is offline   Reply With Quote
