67-72 frame specs...cab mounts
i was wondering if someone had the specs for cab mounts on the frame as well as motor mounts. i have seen dimension sheets on this form but have not seen the specs for the cab mounts
1970 c10 5.3l ls motor ls1 intake, TB, injectors and comp aluminum fuel rails custom ground cam ![]() |
Re: 67-72 frame specs...cab mounts
are you referring to the locations of the cab mount holes with respect to both the length and width of the frame? I had to repair my brackets since they were so rusted out and was seeking the same information. I ended up measuring another frame and figured out everything as close as i could. What are you trying to do with these numbers?
yeah that's what i'm lookin for. well i'm building my own frame from the ground up and i dont have a frame to measure from. my old ones all cut up and almost sure its not straight.
#4 | |
![]() Join Date: Feb 2001
http://67-72chevytrucks.com/vboard/s...d.php?t=194004 http://67-72chevytrucks.com/vboard/s...d.php?t=406751 http://67-72chevytrucks.com/vboard/s...d.php?t=321874
A husband can be right...or...A husband can be happy. ![]() 67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk. ![]() 1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc ![]() ![]() JOHN 17:3...The better side of "LIFE" Remember: Everyday is a good day...Some are just gooder! |
thanks 70cst but i need the frame specs and dimensions i have seen a few on this form but non show the cab mounts and motor mount specs on them.
is this what you are looking for?
Great info. I actually needed this
--------------------------------------------------------------- Jason. 68’ GMC shortbox https://67-72chevytrucks.com/vboard/...d.php?t=794201 72' 2WD Blazer http://67-72chevytrucks.com/vboard/s...d.php?t=425385 67' LongBox C-10 http://67-72chevytrucks.com/vboard/s...d.php?t=691845 InstaGram ybnorml67 |
well i need most of this and this is the image i have seen before but it doesn't show measurements for the cab mounts just their location....
bump.....
Thank you for information! That's what I was looking for.
