01-12-2012, 11:47 PM | #1 |
fuel economy question
I am about to go purchase a 1991 2wd Suburban to replace the crew cab short box that I had built and lost in the big fire.
My plan is to lower the sub and convert to 5.3 ls power. I am doing it for drivability and power but was curious as to what you guys have seen for changes in fuel economy from the factory 305/ 350 to the ls set up. Thanks for your time. Keith |
01-13-2012, 12:47 AM | #2 |
Has more rust than truck...
Re: fuel economy question
14-16 all city driving. Haven't had it on the highway much at all.
01-13-2012, 09:41 AM | #3 |
my 71 LWB 6.0/4l80e gets 15 no matter how its driven. I have not towed with it yet to see what it will get but that is coming up soon.
If wanitng MPGs then go with the 5.3/4l60e combo. the 80e is a massive beast to turn and I think thats why they dont get any mileage.
71 Cheyenne C10 LWB cam'd 6.0/T56 Swap |
01-13-2012, 11:55 AM | #4 |
85 3/4 ton 2wd............
350/400 I got 10mpg 5.3/4L60E I get 17-19mpg |
01-13-2012, 12:14 PM | #5 |
71 SWB 5.3 4L60E 308 gears, 16-17 MPG
1950 Chevy 3100 Ramp Bed 1-ton http://67-72chevytrucks.com/vboard/s...d.php?t=749386 1965 Chevy Step Side 1971 Chevy Short Wide Bed http://67-72chevytrucks.com/vboard/s...d.php?t=277191 1971 Chevy Chevelle 1972 Chevrolet C-30 1 ton 2002 Winnebego Class A MH Ford E-550 Chassis V-10 2005 Dodge Ram 2500 5.9 Cummins 2008 GMC Denali 2020 Jeep Wrangler Unlimited Rubicon |
01-13-2012, 12:32 PM | #6 |
meowMEOWmeowMEOW
cammed lq4 with built 4l80e, I drove WI to KY and around town for the weekend,
averaged 70mph, drove 2hr 45 min between gas stops avg 70x2.75= 192.5 miles / 11.5 gal avg fillup = 16.7mpg That was my "overall" # from that trip. I have to go by time because I don't have the fuel settings on my Scanguage setup. Not bad considering its through the heavy trans, 3:73 rear end and some drag radials..not exactly the most efficient combo. ARound town it was closer to 12-13 but not much below. For a "fun" vehicle its actually one of the most effecient and reliable things I've ever owned.
01-13-2012, 12:37 PM | #7 | |
what cam you have?
clicked your link, Tsunami, or did you change it? I am going with a SMALL cam to keep the stock TC so as to tow without issues, maybe the extra TQ down low will allow it to pick up a few MPGs. Quote:
01-13-2012, 01:00 PM | #8 |
...some say that a aftermarket converter in the 4l80 will help gas mileage?...idk.
my build threads '86 C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415628 '67 C10 http://67-72chevytrucks.com/vboard/s...d.php?t=635078 '63 GMC http://67-72chevytrucks.com/vboard/s...d.php?t=674682 |
01-13-2012, 02:43 PM | #9 |
Just for reference, I have the same exact truck, '71 swb 3.08 gears but only with the original 350/350 combo and I get 12. Don't remember what my 6.0 swap got, but I'm hoping for high teens with my 5.3.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html 5.3 swap into my RUSTY '71 C10 http://ls1tech.com/forums/conversion...71-c-10-a.html |
01-13-2012, 03:42 PM | #10 |
Thanks guys thats awesome, looks like another good reason to move forward.
Keith |
01-13-2012, 10:29 PM | #11 |
kwin,
My 1965 C10 with 6.0 litre LS2 / T56 stock from a 2005 SSR (with Cats) gets an honest 17 mpg average over the last year (8000 mi). (I have all the records and have calibrated the odometer) That is a mix of highway and urban, but mostly highway. Just for reference, my 2008 Vette LS3 with the exact same final drive ratio and 6-speed manual gets an honest 21 mpg over the same roads. All I can figure is Aerodynamic difference. TR
1965 C10 SWB Fleet Two owner LS2 Swap Thread http://67-72chevytrucks.com/vboard/s...d.php?t=413880 |
01-13-2012, 10:41 PM | #12 |
...and prob rolling resistance...lol.
01-14-2012, 03:05 AM | #13 | |
meowMEOWmeowMEOW
We didn't re adjust the computer after switchin to the bigger diameter drag radials, and my lockup was being VERY finnicky (only worked about 30% time it should). I think on top of that, if I had some big tubes instead of the tbss manifolds I'd do a bit better. The lq4 likes the Tsunami and does ok despite the truck intake manifold peaking hp early, if it were an lq9 or I milled the heads a tiny bit it would perk up a chunk. I'm waiting to run FI so not doing that stuff for now.
01-14-2012, 01:13 PM | #14 |
I have an 82 w/ 5.3 & 4l60 swb, everything stock. I did have my local tunner do some work on the pcm. Before I was running a tbi w/ 350 & 200r4. At best I got 12.5. After the swap and running a few tanks . I could tell a lot of diffrence before I even calculated it. I used to get right at 200 miles on a 16gal tank. Now I get about 285 miles on a tank. Now I am close to 18mpg. I have not been at cruise speeds for very long so I dont know what it would do at hwy speed. It may not be much better because of these truck being like a sale in the wind. I am hopeing to get around 20mpg ( wishfull thinking ). But in my case I have about 5.5 more miles for every gal I burn at $3.50 gal ($.086 per mile). That puts me at .47 cents savings for every gal I burn. Keith, you may not see these kind of results because the size and weight of the burb. But I thing you will see some improvement. Good luck with your install. The swap was totaly worth it for me.
Buy the way, I am running a 3.23 gear. With my tire height at 28.3 gives me a 200rpm lower than the stock setup at 60mph. |
