Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Electrical > Truck Audio
Old 01-16-2012, 05:55 PM   #1
Bradydz
Bradydz's Avatar
Question LMC remote unlock, questions?
I bought the remote unlock kit LMC offers, http://www.lmctruck.com/icatalog/cbe/full.aspx?Page=63 at the top left, and I have a few questions to anyone who has bought it and installed it, if there are any out there.
First, do you have any pictures of where you mounted everything? I don't exactly want to put a few holes somewhere, and realize it won't work right..
Also, there is a yellow wire that connects to the controller, but is not mentioned ANYWHERE (unless I just don't see it) in the instructions. It's a single wire, split into two, and are about equal length. Any ideas?
Bradydz is offline   Reply With Quote
Old 01-16-2012, 06:57 PM   #2
jimmydean
jimmydean's Avatar
Re: LMC remote unlock, questions?
i haven't mounted the brain, but buried in my build thread I did a write up taking 2 cheap-o actuators off ebay and installing them in my '66 for keyless entry. Depends on how you want it all to work.
I modified the door latch, but the easiest thing is to attach to the arm.
As for the wires, it is a reverse polarity actuator. Positive on one lead, the other to ground will unlock, switch to lock.
New Project: 1966 LWB C20
Plans:
1/2 ton conversion
Dropmember front
Dropmember rear
Corvette discs
Restored raised bed
http://67-72chevytrucks.com/vboard/s....php?p=4295210
jimmydean is offline   Reply With Quote
Old 01-16-2012, 07:25 PM   #3
Bradydz
Bradydz's Avatar
The yellow wire, totally separate from the actuators? It doesn't go with the rest of the harness, it's a totally separate wire.
Old 01-17-2012, 03:13 AM   #4
dugvera@gmail.com
dugvera@gmail.com's Avatar
Woh! Make sure you get some good documintation and pics please! I want this on my burb.
Doug
66 4x4 GMC Suburban
76 4x4 Chevy Shortbed
dugvera@gmail.com is offline   Reply With Quote
Old 01-17-2012, 12:27 PM   #5
jimmydean
jimmydean's Avatar
Oh, i have no idea on the yellow wire. You sure it's not the antenna or something? How long is it? Pictures would help.
Plans:
1/2 ton conversion
Dropmember front
Dropmember rear
Corvette discs
Restored raised bed
Old 01-17-2012, 04:55 PM   #6
Bradydz
Bradydz's Avatar
Here are 5 pictures of what the controller and the yellow wire looks like. (taken with my phone, don't have another camera..)
It connects on the two-prong side, but only one wire connects to it, which is the yellow wire.
Old 01-17-2012, 04:57 PM   #7
Bradydz
Bradydz's Avatar
And here's some more pictures of the kit.
Old 01-17-2012, 05:01 PM   #8
Bradydz
Bradydz's Avatar
Also, why was this moved to truck audio..?
Old 01-18-2012, 02:16 AM   #9
dugvera@gmail.com
I'm throughing out a guess but antenna wire? Looks like the plug on the back of my home stereo head units am antenna wire. Guess there isn't any stereo/alarm guys around here?
Doug
66 4x4 GMC Suburban
Old 01-18-2012, 02:24 AM   #10
dugvera@gmail.com
Did you happen to notice if there was a replacement solenoid? Id like to try to wire it up to the rear door on my burb too.
Doug
66 4x4 GMC Suburban
Old 01-18-2012, 03:16 AM   #11
Bradydz
Bradydz's Avatar
I was considering that it may go to another controller if you had a 4-door (I'm assuming it is a universal kit, that LMC slightly altered), but you'd think they would mention it in the installation instructions, or at least label the wire or something.. It's got me quite confused, and hoping it isn't a key component.
Do you mean the whole actuator? Because from what I've read from others' posts, you can get the actuators pretty cheap on eBay, for example..
Old 01-18-2012, 03:26 AM   #12
dugvera@gmail.com
Sure if that's what there called? Id just like to have that kit and be able to have it lock and unlock the tailgate/hatch lock on the back door too.
Huh, never thought about a 4 door install. Could verywell be. I guess all you would need is two more wires to run the rear doors too. Wouldn't they just use the pass door wires for that? And why would they loop the two together like that? I'm with you????? Strange they wouldn't even say what its all about in the instructions.
Doug
66 4x4 GMC Suburban
Old 01-18-2012, 03:32 AM   #13
Bradydz
Bradydz's Avatar
Ohh, right. Hmm, I don't know, you'd probably have to tamper with it to make it work, but I don't think they have a specific kit for that.
Actually, there are two other wires on the harness that are for the rear doors if you wanted to, so I don't think that is it, either. Not sure..
Old 01-18-2012, 03:41 AM   #14
dugvera@gmail.com
I went to a class in Medford. Beautiful city. Did the jet mail boat on the river. Good times!
Doug
66 4x4 GMC Suburban
Old 01-18-2012, 03:51 AM   #15
Bradydz
Bradydz's Avatar
It's gettin' pretty crowded, haha. But yes, it can be pretty at times. What was the class for?
I just found something I must've skipped over before on the main harness. There are two wires that do not go to anything I have, and one wire is white, the other is brown. I just looked at the tiny wiring diagram, and the two I found go off to the left, and connect to a, "spare negative trigger", and where the wires are, the white says "unlock", the other says, "lock". Is this yellow wire with relays considered a negative trigger, you think?
Old 01-18-2012, 04:02 AM   #16
dugvera@gmail.com
Perhaps a static switch that can be mounted on the door to activate the locks?
Learning a CNC program called microvellum. Its a cabinetry program used to design and export g code to a CNC machine that cuts/machines parts.
Doug
66 4x4 GMC Suburban
Old 01-18-2012, 08:21 PM   #17
tubbedII
needs more $$$
tubbedII's Avatar
Sorry, I provide no help, but I've been searching for a kit like this, and it seems to be the cheapest out there...so I'm just watching and hoping to see it installed and working!
As a random guess about the yellow wires, antenna sounds the best so far since they don't have connections on the ends like the others. The only thing is they are awfully thick and antenna wires are usually the thinnest and black.
Keep us posted and take pics of the install!
1970 2wd Blazer
tubbedII is offline   Reply With Quote
Old 01-18-2012, 08:26 PM   #18
dugvera@gmail.com
I was thinking the wires looked thick too. Could be like bradydz siad lmc kinda put the kit together and the just used a big wire? Maybe?
Doug
66 4x4 GMC Suburban
Old 02-23-2012, 02:04 AM   #19
rbagley
rbagley's Avatar
I don't know if someone already said it or not, but the yellow wire is for headlights. It makes them flash once for lock and trice for unlock I think.
rbagley is offline   Reply With Quote
Old 03-06-2012, 03:33 AM   #20
Bradydz
Bradydz's Avatar
To any who wanted to see this being installed, you should not have to wait much longer. I kept putting it off, but I will be working on, and will hopefully finish, installing it tomorrow morning. I will take pictures as I go, and post how it works, and such.
Old 03-06-2012, 03:41 AM   #21
dugvera@gmail.com
Excellent!
Doug
66 4x4 GMC Suburban
Old 03-06-2012, 12:29 PM   #22
tubbedII
needs more $$$
tubbedII's Avatar
Anxiously waiting!
1970 2wd Blazer
Old 03-06-2012, 02:08 PM   #23
Bradydz
Bradydz's Avatar
Sorry to let you guys down, but I woke up with Mono-like syptoms, so I'm just going to be taking it easy. Again, sorry guys! I'll get it installed as soon as I can!
Old 03-06-2012, 02:44 PM   #24
tubbedII
needs more $$$
tubbedII's Avatar
I'm going to have to use that excuse for work tomorrow! haha
1970 2wd Blazer
Old 03-08-2012, 01:18 AM   #25
dugvera@gmail.com
Let me guess your dog ate thr parts? Jahaha just jokes.
Doug
66 4x4 GMC Suburban
lmc, remote
