69 c/10 lwb fleetside
stripped wiper arms
is there a solution for the crappy wiper arms the s10s have my brother has had them strip atleast 2 times.i havent seen it when he has the arms off so i dont even know how its made but he said its real soft metal or maybe even plastic and you just draw on to the wiper studs to make splines and its to soft to last. is there a way to put earlier arms on it or any other fixes to make them stronger?
69 lwb fleetside ![]() 67 swb fleetside ![]() (2) 72 lwb fleetside 50 swb no bed ![]() 65 impala ss ![]() 65 1 ton flatbed ![]() |
Re: stripped wiper arms
nobody had problems with these
BAD BOW-Silverado XST
Not me. I rarely take off the wipers. I've seen people ruin them by forcibly installing arms. Use a little WD40 and toothbrush to clean the splines. Pull the arm back all the way before pushing down on it.
blood type; Retumbo
they have problems when the windshield gets iced and people turn wipers on without loosening the wipers first. just about all GMs do this.
remove arm, clean splines on shaft with small pick tool and reinstall with about 15 ft.lbs. torque. if they have stripped more than once you may need new arms
Man rule #77...if you own a 67 stepside with a caddy 472 you will never be in danger of loosing you man card |
Once I was sitting in traffic wipers full blast pass. side popped off an the whole arm dissapeared for a second then crashed down in the middle of the hood
81 camaro 355 4/spd 342 posi my first love ![]() 67 swb step 454/4spd ott 373 posi 4/7 drop. 2000 s10 zr2 little blue truck that never gets stuck. '74 heald super bronc vt8. tecumseh powered moon rover. |
~Rest In Peace~
j/b weld it on there LOL j/k
is it fast ? it has a lighting bolt donut? B___H please, I can remove 90% of your so called "beauty" with a kleenex |
