Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > The 1973-1987 Chevrolet & GMC Pickups Parts Board
Old 01-19-2012, 06:03 PM   #1
1979 GMC Sierra
1979 GMC Sierra's Avatar
WTB: heat stove for V8 350
Looking for a heat stove for a V8 350 engine. Thanks,
Travis
1979 GMC Sierra 3/4 ton Camper Special
1976 Chevy Cheyenne 3/4 ton
1979 GMC Sierra is offline   Reply With Quote
Old 01-20-2012, 08:37 AM   #2
RandyP
Getting Old; Going Broke
RandyP's Avatar
Re: WTB: heat stove for V8 350
You talking about the pipe between the manifold and the air cleaner? If so, solid pipe or flexible, depends on the year of the air cleaner I believe.
Why is every used 350 sbc out of a corvette?
There's only two things that excite a man, expensive toys and real expensive toys.
VEGETARIAN: That's an old Indian word meaning "I don't hunt so good."
When the going gets tough, switch to power tools.
RandyP is offline   Reply With Quote
Old 01-20-2012, 05:38 PM   #3
1979 GMC Sierra
Yes, that's what i'm looking for...the pipe that sucks heat from the exhaust manifold and sends it through the air cleaner to warm up the carburetor. I believe it's a solid pipe...but if there's a flexible one that will work for a 350 engine, then i could use it as well. I may have to get something made as a substitute, cause i don't think many people have this part. It rots off, and isn't a necessity...and rebuilt engines don't come with a heat stove. It just helps to have it if you live in a cold climate. I was just hoping someone had one by chance.
Old 01-20-2012, 08:08 PM   #4
madcow75
madcow75's Avatar
The local parts stores used to allways have them in stock. Check uap, the should be able to help you. They are usually in the HELP parts.
madcow75 is offline   Reply With Quote
Old 01-20-2012, 11:12 PM   #5
BLE 'BURBAN
In the Forgotten far North.
BLE 'BURBAN's Avatar
2" i.d. carb pre-heater hose and at least one hose clamp yo either hold it to the riser on the manifold(that's where mines at) or to the down pipe on the bottom of the snorkel
1987 R3500 CREW CAB DUALLY (BIG RED)Acquired 06/12/2015
1990 chevy suburban V2500 5.7L
My cluster Mods-Nov 2007
overhead console Stereo install Round 2 Aug 2009
Heated/turn signal mirror upgrade
BLE 'BURBAN is offline   Reply With Quote
Old 01-22-2012, 02:07 PM   #6
classicchev
classicchev's Avatar
pic would help. I have a few, just want to hone the search a little..
67- 72 Parts collecter
classicchev is offline   Reply With Quote
