Spindles for c10 longbed same as shortbed
1) Can anyone tell me if the spindles for a C10 long bed are the same as for a C10 shortbed?
2) If so, then is the ackerman angle more correct on the long or shortbed? Thanks |
Junior Member
Re: Spindles for c10 longbed same as shortbed
Question 1 - Yes
Question 2 - You lost me, hopefully some one else will chime in.
'67 Chevy C-20 short stepper - build complete, 454/SM-465. '75 C-30 Single Cab DRW-350 small block/NP-435. '77 GMC-6500 Dump Truck, 427 Tall Deck. '92 GMC K-3500 Duallie, 454/4L80E. |
![]() Join Date: Mar 2011
I don't think the ackerman is going to be significantly different because of the change of wheelbase. Remember that the difference in wheelbase is less than 11%.
Ackerman is the difference in the angle between the inside and outside wheels at full lock. |
Thanks for your help
