01-25-2012, 11:30 PM | #1 |
whos truck is this i gotta ask?
this is the koolest truck iv seen in a while. i would love to know how hard and how mutch this swap cost.
01-26-2012, 12:15 AM | #2 |
Re: whos truck is this i gotta ask?
The swap is not that hard I have done it on 8 trucks now. It is very time consuming though. After doing a 6" IFS lift on my buddy's 2500HD I will not do another lift unless it is a Solid Axle Swap.
1949 Five Window, 1973 Step Side, 2000 Z71 |
01-26-2012, 12:17 AM | #3 |
Real Projects never die
Ill put it this way, ive got a few lawn ornaments My name tag says Ryan KansasTwister On other forums
01-26-2012, 02:01 AM | #4 |
If you get a 3500 HD in those body styles, they already have a solid front axle, but they are only 2wd. The swap is even easier, the leaves and mounts are all there.
1970 : Chevy: K20 "Frank the Tank" 6.0 LS, 4L80E, 14 bolt, and Dana 44 1970 K5 Blazer CST 350, TH350, Np205, Dana 60 and 14 bolt General Motors Master Certified wrench swinger ASE certified Master auto tech Instructor of Automotive Technology |
01-27-2012, 05:50 PM | #5 |
I have done a swap like this to a 1/2ton 2wd and that was pritty easy. But how hard would it be to do it to a 3500 4x4 a 96.
Posted via Mobile Device |
01-27-2012, 09:28 PM | #6 |
Easy as long as you get the right parts and know from the start how you want it.
Do you want to use the factory transfer case? If so you need a ford of new dodge front axle. If you want to go all GM then you will need a transfer case along with a Chevy front axle. The transfer case needed is from a 90-91 burb/crew cab with a TH400, 4L80E, or a SM465. If you don't mind loosing OD then you could use a tranny/t-case from a 73-87.
01-27-2012, 10:46 PM | #7 |
only thing i found hard about these kinda swaps is finding the front axle
01-27-2012, 10:47 PM | #8 |
and a guy were i live has this truck up for sale i want it bad
01-27-2012, 10:58 PM | #9 |
The axles are easy to find around here. Between my friends and I there are probably 7 front axles kicking around behind my barn. Craigslist is your friend along with other true 4x4 guys. I don't know any 4x4 guys that don't have at least 1 extra set of axles laying around.
01-27-2012, 11:19 PM | #10 |
cool what axles and gears would you recomend
01-28-2012, 12:05 PM | #11 |
Front axles are all over the place and cheap. If you want a Dana 60 for an ultimate truck,that's different. But,if you don't really need all a Dana 60 offers,you'd still be miles ahead and way tougher than original using a 3/4t axle on an 8-lug or a 1/2t axle on a 1/2t. You can always toss a Dana 60 in later if you really think you need it.
Trucks like the one this thread was started over were sold new through upfitters. I remember back around 2000 seeing them for sale built from HD3500s with 19.5 wheels.
