Old 01-26-2012, 03:45 PM   #1
chisler
chisler's Avatar
Spark plug wires and routing!!!!!
Looking for some ideas on on clean looking set up...just purchased a MSD wire set for my 72 chev 4x4....either the wires are too long or too short..I have the stock exhaust manifolds...and have upgraded to the Hei ...was trying to find the straight...socket boot to the plug....any recomendations on a kit and part number that works and looks clean...any pics...must be some nice set ups out there!!!! 350 small block...Thanks
chisler is offline   Reply With Quote
Old 01-26-2012, 08:47 PM   #2
Mike C
Mike C's Avatar
Re: Spark plug wires and routing!!!!!
Have you searched? This has been discussed quite a bit. If you bought pre-made replacements, they are designed to go down the back of the block and forward to to each plug. This is MUCH better than the over the valve cover, over the manifold version. YMMV.
If running an HEI the wire to get is a '75 to '79 Corvette small block wire which has HEI boots and the 90's on the plugs to correctly route up to the rams horns manifolds.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 01-27-2012, 03:56 AM   #3
chisler
chisler's Avatar
Thanks Mike C. will do a search and look into your tip on the wires you mentioned....Thanks
