Old 02-02-2012, 11:23 AM   #1
lyrikz
PITbut
lyrikz's Avatar
Wipers blow fuse only on low setting?
:UPDATE:
So i might have figured out the issue. What size fuse should be in the wiper motor location? Anyone know?
Finally getting the truck 100%. Adding the final things like wipers and what not. The wipers have sat for 4 years. I lubed everything up and turn on the wipers. They do about 2 swipes and then pop the fuse. LIttle more lube and they do about 3 swipes and pop the fuse. Heres the thing, it ONLY pops the fuse when they are on the lowest setting. If i click it to the 2nd or third setting they stay on fine.
71 chevy pu.
Thoughts?
New project. 1971 Twin Turbo blazer
http://67-72chevytrucks.com/vboard/s...d.php?t=676047
My new YOUTUBE channel.. Videos of my truck and a current walk around.
Lyrikz74 Youtube channel DONE! SOLD!
My 1971 stepside build thread
My Build Thread UPDATED 6/11. DONE
and sold.
lyrikz is offline   Reply With Quote
Old 02-02-2012, 12:33 PM   #2
eurospec1
eurospec1's Avatar
Re: Wipers blow fuse only on low setting?
71 chevy pu.
Thoughts?
Wire shorted on the low side between your switch and the motor would be my guess
68 SWB Fleet 383
eurospec1 is offline   Reply With Quote
Old 02-02-2012, 12:39 PM   #3
alsriv2
alsriv2's Avatar
Location: Formerly MD and San Diego, now loving life in Arizona
Might possibly be a defective switch. If the low position is worn, it could provide a path to a ground causing the failure.
Al
'69 Gmc 2500 Custom Camper
'69 Chevy C10 396
alsriv2 is offline   Reply With Quote
Old 02-02-2012, 12:46 PM   #4
lyrikz
PITbut
lyrikz's Avatar
Al
'69 Chevy C10 396
Wire shorted in the motor internally???
and sold.
Old 02-02-2012, 01:03 PM   #5
alsriv2
alsriv2's Avatar
I was thinking the dashboard turn switch itself. I once had a '67 that one of the positions would not operate the wipers at all. I replaced the dash switch and problem solved.
Al
Old 02-02-2012, 02:11 PM   #6
davepl
davepl's Avatar
Well, I'm not certain how the switch controls speed, but if it uses a resistor to limit current for the low speed, and that resistor was shorted, then it would blow the fuse on LOW but cause no problem on HIGH. Just a guess.
Use an ohmmeter to measure the resistance from input to the output(s) when the switch is off, low, and high. Should be infinite, some number, and zero. If it's zero in both low and high, that's your short I would imagine.
davepl is offline   Reply With Quote
Old 02-02-2012, 02:17 PM   #7
lyrikz
PITbut
lyrikz's Avatar
They have resistors back on those old things?
and sold.
Old 02-02-2012, 02:38 PM   #8
D.PASSMORE
One of the First
D.PASSMORE's Avatar
Thought: make sure the wiper arms are moving freely. Way back when, I remember that my wiper arm studs were corroded up and were hard to turn. I went through a few motors before i figured it out. R&R'd them and never had another problem.
D.PASSMORE is offline   Reply With Quote
Old 02-02-2012, 03:35 PM   #9
lyrikz
PITbut
lyrikz's Avatar
Possible, but they move pretty free on a higher setting and they move free on the lower setting...
Hmmm. On the washer switch there is three wires. ground, power to squirter and power to wiper motor. So there has to be a resistor in there somwhere
and sold.
Old 02-02-2012, 03:49 PM   #10
schurg
I'm pretty sure the switch controls the ground side of the wiper motor. the power goes from the fuse panel straight to the motor assembly... I'd say there is an issue in the wiper assembly itself.
schurg is offline   Reply With Quote
Old 02-02-2012, 04:05 PM   #11
davepl
davepl's Avatar
Yes, they use resistors, but they're probably integral to the motor, not in the switch, if for no other reason than getting rid of the heat... note that the hi/lo heater fan switch has to use a big external resistor in the airflow path.
In any event, I believe the wiper switch provides two different paths to ground. The power wire at the motor is hot with ignition, and low grounds part of the internal resistor network and high grounds both parts.
That said, I was wrong in my original post - and agree it's pretty much got to be a fault in the motor, not the switch. You could still use the ohmmeter to confirm it, but you'd have to do it at the wiper motog connectors.
Old 02-02-2012, 04:11 PM   #12
lyrikz
PITbut
lyrikz's Avatar
I may have figured out my problem. I replaced all my fuses, or removed them. Well, i think i put the wrong fuse in. What size fuse should be in the wiper motor location?
and sold.
Old 02-02-2012, 04:16 PM   #13
D.PASSMORE
One of the First
D.PASSMORE's Avatar
I thought so too, until I physically tried to move them.
Popped a few fuses, fried the motors after awhile...
Good luck.
DAVID PASSMORE
ST AUGUSTINE ,FL
ZIP 32084
'71 SWB K/10 CUSTOM DELUXE (Chili)
'72 BLAZER K/5 Muscle Truck (Mule)
'72 LWB K/20 CHEYENNE (Blackie)
Old 02-02-2012, 05:03 PM   #14
va72longhorn
va72longhorn's Avatar
Its more of a current draw issue than it is a short issue. If it was a direct short, you wouldnt get two swipes of the wipers before it blows. If the linkages and joints are rusted or gumed up this will create more of a current (amperage) draw than normal. Its not quite as bad in the higher speeds because its getting " a running start". Kinda like pushing a truck with the tires half flat, it takes more energy, but once it gets going it aint bad. Putting a larger fuse in will only buy you time. Take the arms off and make sure everything is lubricated good. Use some penertrating oil (WD40, Blast, etc) on the all the linkages and then run the wipers with out the arms on them for a couple of minutes. Then stick the arms back on. After sitting for four years, theres nothing to lose.
va72longhorn is offline   Reply With Quote
Old 02-02-2012, 05:05 PM   #15
lyrikz
PITbut
lyrikz's Avatar
LOL, no one is reading my other posts. The fuse is the wrong size. I have a 3 amp fuse in there. 3. The fuse that should be in there is 25 amp i believe. I just was hoping someone could go out to their truck and tell me what the correct size is for the wiper fuse. I cant find a stock diagram or anything like that.
and sold.
Old 02-02-2012, 05:12 PM   #16
davepl
davepl's Avatar
According to my owner's manual the wiper fused is supposed to be 20 AGC. My lawyer won't let me say you can run a 25, but I'd imagine that's ok too.
I bet it'd pop a 3 amp fuse pretty quick! I'm surprised it would surive on high either.
Old 02-02-2012, 05:14 PM   #17
john
member #16
john's Avatar
here you go.
john is offline   Reply With Quote
Old 02-02-2012, 05:15 PM   #18
lyrikz
PITbut
lyrikz's Avatar
Sweet, 20 it is. Im suprised to.. But this fuse is wire thin.. Then i saw some pics of other wiper fuses and was like WOOOAH thats way wrong... I believe i put that small ass fuse in EVERY fuse location so when i put power to everything the first time, nothing would blow. Well, nothing did blow except for the wiper motor.
and sold.
Old 02-02-2012, 05:16 PM   #19
lyrikz
PITbut
lyrikz's Avatar
Originally Posted by john View Post
here you go.
OMG im such an idiot.. IT SAYS IT RIGHT ON THE FUSE PANEL. lol. Wow.
Talk about overlooking something...
Sorry for wasting all your guys time.
and sold.
Old 02-02-2012, 05:18 PM   #20
va72longhorn
Yeah, Im very surprised that it ran at all on a 3 amp.
Old 02-02-2012, 05:21 PM   #21
D.PASSMORE
One of the First
D.PASSMORE's Avatar
I believe a 20 Amp
Old 02-02-2012, 05:28 PM   #22
lyrikz
PITbut
lyrikz's Avatar
Yep, ran all day on high. Low it would pop it.
and sold.
Old 02-02-2012, 05:44 PM   #23
lil hoodlum
lil hoodlum's Avatar
LOL!
We all have those moments!
Keith
lil hoodlum is offline   Reply With Quote
Old 02-02-2012, 06:20 PM   #24
lyrikz
PITbut
lyrikz's Avatar
Originally Posted by lil hoodlum View Post
LOL!
Keith
I was searching all over the internet for this info. Looking at those fuse panels and just did not see the 20 amp right there on it...
Sigh... oh well.
and sold.
