Old 02-04-2012, 03:06 PM   #1
rocket20
quick ?
i am swaping out 71 1/2 ton axle to 76 1 tons do i need to do any thing to my drive shaft ? if so what and thanks
rocket20 is offline   Reply With Quote
Old 02-04-2012, 07:17 PM   #2
Zoomad75
K5Camper
Zoomad75's Avatar
Re: quick ?
Chances are the u-joint size on the 1 ton axles is larger than the 1/2 ton axles. You can get a conversion u-joint that has the both sizes to allow the use of your stock driveshafts. The other option (the strongest too) would be to have your drivelines rebuilt with the 1 ton size yokes, so that stronger u-joint could be used.
Rob Z.
1975 K5 350/465/205/D44/12b 4" lift on 35's- RIP
1991 K5 8.1L/NV4500/241/D44/14b FWC Camper
Zoomad75 is offline   Reply With Quote
Old 02-04-2012, 08:27 PM   #3
Mike C
Mike C's Avatar
Re: quick ?
When I swapped in my semi-floater, I had to get a conversion u-joint and I had to re-drill the spring perches to move the axle back or the driveshaft was going to be too long. This had the advantage of centering the wheel in the wheelwell. I had a custom cv joint rear shaft built to order after the lift, so if you have a stock driveshaft and a lift you may not have to mess with that.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 02-06-2012, 10:51 AM   #4
rocket20
Re: quick ?
do you know the number of the conversion u-joint and have you had any vibration problems? any other tricks for the swap
