Old 02-05-2012, 09:56 AM   #1
Mudder
Mudder's Avatar
4Wheel disk brake question?
What is everyone using for the master and booster that have gone with the rear disks? Nice to find something that is a bolt on. Mine have been decent but the seals in the master go bad every once in a while.
Mudder is offline   Reply With Quote
Old 02-05-2012, 12:05 PM   #2
freakshow108
freakshow108's Avatar
Re: 4Wheel disk brake question?
Check out Frank on the board he goes by Pickmup. I have a 71 K20 that I converted to 4 wheel disc and he set me up with a firewall forward kit for a smoking price. Hope this helps.
freakshow108 is offline   Reply With Quote
Old 02-05-2012, 01:11 PM   #3
6600DURAMAX
6600DURAMAX's Avatar
I am just using an ebay hydro boost unit with a disc/disc master and proportioning valve. Works great till the power steering belt jumps off. hahaha
1972 K5 Build - plans - LS3-6L80e-One Tons.....
1971 CREWMAX Build.....at body shop for couple more years
6600DURAMAX is offline   Reply With Quote
Old 02-05-2012, 07:48 PM   #4
argonaut
argonaut's Avatar
I have a CPP setup. Its an 8" dual diaphragm booster with what I believe is a corvette type master cylinder and an aftermarket proportioning valve.
Jason M. @argonaut62
1972 K5 Blazer CST, Turquoise
1966 K20 Short Fleet Pickup, Big Ugly
1964 C10 Short Fleet, Gertrude
2001 Porsche 911 Carrera
1996 Ford Bronco XLT
1980 Jeep Wagoneer
2008 Honda CBR1000RR
2005 Honda RC51
1981 Honda CB750C
No dis-assemble Johnny Five! No dis-assemble!
argonaut is offline   Reply With Quote
Old 02-05-2012, 11:40 PM   #5
ghettoluxury
ghettoluxury's Avatar
Factory GM hydroboost from 73-87.
1949 Five Window, 1973 Step Side, 2000 Z71
ghettoluxury is offline   Reply With Quote
Old 02-06-2012, 10:56 AM   #6
rocket20
did you guys get a kit or put it together from junk yard or parts store
rocket20 is offline   Reply With Quote
Old 02-07-2012, 08:56 AM   #7
6600DURAMAX
Some pics of my setup, I really needed the hydroboost since my cam only makes about 8-9 inches of vacumm at idle in park and around 5-7 in gear.
I bought the master and prop valve from PirateJack, hoses were custom made, and the hydro boost was a new Ebay item. bolted up faily easily just had to cut and weld my brake rod
Old 02-07-2012, 03:25 PM   #8
argonaut
argonaut's Avatar
Mine was a kit from CPP. It came pre-assembled with bracket, booster, master cylinder and prop valve, and push rod. I had to modify the pushrod a bit to get the correct length and made a new hole in the pedal arm to mount the pushrod to. I also had to add two additional holes to the firewall to mount the bracket.
My rebuilt, stockish 402 big block pulls plenty of vacuum at idle so the vacuum diaphragm booster works well for me.
1980 Jeep Wagoneer
2005 Honda RC51
1981 Honda CB750C
Old 02-07-2012, 05:23 PM   #9
Burt4x4
Burt4x4's Avatar
I used a K30 Booster/Master (Dual diaphram)(plumed oppisite of the 1/2ton master).
My P-valve is still stock 1972. My disk brakes work but I still want to open up the P-valve and remove the guts for the rear and instal in-line adj. P-valve...or they even sell a replacement 4wheel disk p-valve a few have used...
1972 K5 MPFI454/Sm465/Np205/D60/14FFd/Re-Centerd H1s w/Swamper Iroks
Burt4x4 is offline   Reply With Quote
Old 02-09-2012, 09:50 PM   #10
rocket20
do you recomend the hydro boost setup ... how is the pedel responce
